Problems with Hue Emulation an Color Temperatur of the CCT Color and device not responding
Hi, I have a problem with two RGB CCT lights an HUE Emulation. One is flashed with tasmota and one with esphome. I want to control them with Alexa over Hue Emulation. I added this in the configuration
emulated_hue:
  listen_port: 80
  host_ip: 192.168.1.1
  off_maps_to_on_domains:
    - script
    - scene
  expose_by_default: false
  entities:
    light.yeelight_light_ceiling20_ceiling_light:
      hidden: false
    light.yeelight_light_ceiling20_ambient_light:
      hidden: false
    light.yeelight_light_ceiling20_night_light:
      name: "Yeelight Nachtlicht"
      hidden: false
    light.tasmota_44237c37847e_light_light_1:
      hidden: false
    light.esstisch:
      hidden: false
now I have multiple devices, but no color selection for the CCT Light
the http://192.168.1.1/api/pi/lights returns:
    "1": {
        "state": {
            "on": false,
            "reachable": true,
            "mode": "homeautomation",
            "bri": 1
        "name": "Yeelight Nachtlicht",
        "uniqueid": "00:3d:6c:18:2e:97:18:f6-fe",
        "manufacturername": "Home Assistant",
        "swversion": "123",
        "type": "Dimmable light",
        "modelid": "HASS123"
    "2": {
        "state": {
            "on": true,
            "reachable": true,
            "colormode": "ct",
            "ct": 153.84616088867188,
            "bri": 191
        "name": "Yeelight Licht",
        "uniqueid": "00:a4:db:f9:a0:a1:2e:25-e4",
        "swversion": "123",
        "type": "Color temperature light",
        "modelid": "HASS312"
    "3": {
        "state": {
            "on": false,
            "reachable": true,
            "bri": 1,
            "colormode": "hs",
            "hue": 0,
            "sat": 0,
            "effect": "none"
        "name": "Yeelight Farbe",
        "uniqueid": "00:ad:c3:86:33:32:0d:95-33",
        "swversion": "123",
        "type": "Color light",
        "modelid": "HASS213"
    "6": {
        "state": {
            "on": false,
            "reachable": true,
            "bri": 1,
            "colormode": "hs",
            "hue": 0,
            "sat": 0,
            "effect": "none"
        "name": "Esstisch Farbe",
        "uniqueid": "00:d3:c3:49:d3:ff:64:42-11",
        "swversion": "123",
    "7": {
        "state": {
            "on": false,
            "reachable": true,
            "colormode": "ct",
            "ct": 153,
            "bri": 1
        "name": "Esstisch Licht",
        "uniqueid": "00:77:8b:a9:ee:f9:f3:b6-82",
        "swversion": "123",
The type “Color temperature light” is correct, isn’t it ? I have also the message in the Alexa app for the 5 devices that the connected device is not responding (orig. German “Gerät reagiert nicht”)
If I change something in the Alexa app, it will change the state or switch the light part.
So where is there the bug, Alexa, hue emulation, configuration or is this still not possible ?
