Problems with (initial) Z-Wave configuration
recently switched to a RPi4, running the Home Assistant Image (32-Bit).
Decided to renew my cvonfig completely, so far everythings works, but having issues with Z-Wave.
I use a Aeotek Z-Wave stick, which ran fine on my previous RPi3.
Already rebooted the whole system, restarted the Z-Wave network, etc.
The log told me following:
2020-10-07 13:35:31.250 Always, OpenZwave Version 1.4.3469 Starting Up
2020-10-07 13:35:38.771 Info, Setting Up Provided Network Key for Secure Communications
2020-10-07 13:35:38.772 Info, mgr,     Added driver for controller /dev/ttyAMA0
2020-10-07 13:35:38.772 Info,   Opening controller /dev/ttyAMA0
2020-10-07 13:35:38.772 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-10-07 13:35:38.772 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-10-07 13:35:38.772 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-10-07 13:35:38.772 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-10-07 13:35:38.772 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-10-07 13:35:38.772 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-10-07 13:35:38.772 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-10-07 13:35:38.773 Detail,
2020-10-07 13:35:38.773 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-10-07 13:35:38.773 Detail, contrlr, Notification: DriverFailed
No clue what the problem is and why it is not setting up?
Beside the Z-Wave stick, i have a rfxtrx USB controller running, but had the same for my old RPi3 and it runs still fine on the RPi4.
I am using the integration with the device name /dev/ttyAMA0 as shown in “ha hardware info” command on the terminal add-in.
Thanks for help in adavnce!
/ Ralf
There are known issues with the Aeotec Z-Wave stick and the rPi4: Setting up Aeotec Z-Stick Gen5, Z-Wave Plus USB on Raspberry Pi 4
The recommendation to fix it is to put it on an externally powered USB hub as the rPi4 is really strict about power output from the USB ports.
Thanks for this help, didn’t saw it in my searches.
/ Ralf
Just saw Aeotec released a Gen5 PLUS stick now which they confirm RPi4 compatibility.
Anyone already used this stick? Did not see where it is available in Germany, the company listed by the vendor is somewhat freaky…
/ Ralf
