Thank you for your support, highly appreciated!
I should of course have checked the logs - I don’t understand why I only focused on ETS and it’s traffic…
Regarding the climate entity issue, when I change the setpoint temperature in HA I get the following in HA logs:
2023-09-29 10:58:44.081 WARNING (MainThread) [xknx.cemi] CEMI Frame failed to parse: <CouldNotParseCEMI description="APDU LEN should be 0 but is 16 from 1.1.255 in CEMI: bcf011ff19000003f110002a19dcb80c52cd891d8e18c1fb" />
2023-09-29 10:58:47.031 WARNING (MainThread) [xknx.log] L_DATA_CON Data Link Layer confirmation timed out for <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.255")" dst_addr="GroupAddress("3/1/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<SecureAPDU scf="<SecurityControlField tool_access=False algorithm=CCM_ENCRYPTION system_broadcast=False service=S_A_DATA />" secured_data=<SecureData sequence_number=180822521868 secured_apdu="52cd891d" message_authentication_code="8e18c1fb" /> />")" />
2023-09-29 10:59:01.810 WARNING (MainThread) [homeassistant.helpers.script] Error in 'if[0]' evaluation: In 'or' (item 2 of 2):
In 'template' condition: ValueError: could not convert str to datetime: '2023-09-02 23:00:00'
ETS does not show any traffic (however I believe yesterday I got a messages on the bus, but now I am uncertain).
For the sensor issue, I see the following when the sensor periodically sends it’s temperature (3/0/0) and humidity (3/6/0) values:
2023-09-29 11:11:53.565 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5e]" />" />")
2023-09-29 11:11:57.518 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5b]" />" />")
2023-09-29 11:11:57.557 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/6/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x15,0xc3]" />" />")
I have attached a image below of the date seen from ETS.
On row 18 the heating controller requests the temperature and the sensor replies on row 19. On row 14 and 15 HA does the same (both temperature and humidity), but without any reply. The messages also look different (“Sec” instead of “GroupValue_Read”). From the same period, I get the following logs. Please note that for some reason there is a minor time skew between the applications.
2023-09-29 11:13:18.353 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x59]" />" />")
2023-09-29 11:13:21.344 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5e]" />" />")
2023-09-29 11:13:27.329 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x59]" />" />")
2023-09-29 11:13:30.321 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5e]" />" />")
2023-09-29 11:13:42.292 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x59]" />" />")
2023-09-29 11:13:56.255 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x60]" />" />")
2023-09-29 11:13:58.251 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5a]" />" />")
2023-09-29 11:15:24.600 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 3/6/0
2023-09-29 11:15:24.601 WARNING (MainThread) [xknx.log] Could not sync group address '3/6/0' (Master Bedroom - Current Humidity - Value)
2023-09-29 11:15:26.359 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 3/0/0
2023-09-29 11:15:26.360 WARNING (MainThread) [xknx.log] Could not sync group address '3/0/0' (Master Bedroom - Current Temperature - Value)
2023-09-29 11:15:37.863 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.21")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />")
2023-09-29 11:15:37.898 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xc,0x5a]" />" />")
2023-09-29 11:16:56.772 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5c]" />" />")
2023-09-29 11:18:00.653 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x60]" />" />")
2023-09-29 11:18:01.653 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5a]" />" />")
2023-09-29 11:20:37.843 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.21")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />")
2023-09-29 11:20:37.883 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xc,0x5a]" />" />")
2023-09-29 11:21:48.093 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x60]" />" />")
2023-09-29 11:21:50.089 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5b]" />" />")
2023-09-29 11:21:56.041 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5d]" />" />")
2023-09-29 11:25:04.581 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x60]" />" />")
2023-09-29 11:25:06.575 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5b]" />" />")
2023-09-29 11:25:37.828 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.21")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />")
2023-09-29 11:25:37.868 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xc,0x5b]" />" />")
2023-09-29 11:26:55.265 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/0/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc,0x5e]" />" />")
2023-09-29 11:26:55.301 WARNING (MainThread) [xknx.data_secure] Could not decrypt CEMI frame: Discarding frame with plain APDU for secure group address: CEMILData(src_addr="IndividualAddress("1.1.30")" dst_addr="GroupAddress("3/6/0")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x15,0xc3]" />" />")
