Problems with latest HA version
Are you trying to log in with http://homeassistant.local:8123? If this is problematic you could try using the actual IP address eg http://192.168.1.99:8123
I get the same results if I use local IP and the Nubu Casa URL, on and off local network.
That’s far from the “latest” version, try 2021.2.3 instead :wink:
That’s the version I’m on…I looked at the top of the HA page and saw 2021.1.5 listed and mistakenly put that as the version I updated to.
I lot of people have the same problem. I had to downgrade to OS 5.5 and delete HA database to fix my problem that’s similar to your. However it’s most probably database problem. It’s probably too big (around 900MB)
This is exactly what I had in mind as read through all this ha-audio desater. The ha gets more and more unstable, if you dont take the time every release and refactor everything. Or worse, doing a complete new setup, because the configuration found in the documentation some years ago, is no longer supported… wtf
Im really into HA and spend hours per day to optimize and improve. But even for me hardcore user, its getting more and more frustrating and not fun at all anymore.
When updating to 2021.2.X I found my database got corrupted, causing slow response. I stopped HA, deleted the database, restarted and all has been fine since.
It’s not ideal that the update has caused a corrupted database for us few users but it’s hardly a widespread issue with cause to call the project a joke.
what error messages are in your log file?
Excuse my harshness, but cool me once fair enough. Fool me three times, well… :sweat_smile:
Well… you did post two threads basically about the same issue…
That is unfair! There are a few issues but, unless you’ve contributed significantly to the project, you (like most users) really can’t complain.
This is an amazing platform and works incredibly well given the right hardware and support - and user care. Simple things like reading the ‘breaking changes’ section before upgrading make a big difference.
Rather than call it crap, maybe offer your help to fix the problems?
I can’t remember the last time I had to change anything because of a release.
I think the issue is when people skip some releases then upgrade.
Agreed. My process is to read the update notice, run the release through the ‘Check Home Assistant configuration’ tool, Understand what is likely to need changing then do the upgrade. I’ve been running it for probably about 2 years now and can honestly say that any failures have been self-inflicted!
I have not even updated. It just crashed out of nowhere this time…
If it crashed what do the logs say? Is the hardware OK? SD card failure, perhaps? I suggest running it on an Intel NUC with an SSD - you won’t look back.
This appears to be the issue I am having now. I guess the db is malformed. So will need to figure out how to delete it via cli
@beauwilliams
I went searching the forums for this issue because since the upgrade my HA instance has become unstable and crashes at times during the night and evening. Logs shows an sql error i have not seen before, looks alot like posted above. My next move is to erase the database as well, just need to figure out how to do that the right way using the mariaDB addon.
My first thought was that my mSata disk on the proxmox host was going bad, but reading this thread i realise it may be some kind of bug corrupting the database that is the root cause.
Yes I still have not figured it out yet.
I sort of gave up last night. I can not get SSH access, Web GUI etc.
Think the solution is to delete the DB, but through the CLI am not sure. I am so used to ssh and a normal bash shell.
Perhaps we can escape the ha shell and then just browse the fs as if we had SSH’d in?
@dtx and @beauwilliams Yes, the fix is to delete your database as I mentioned previously (in the combination of threads you posted in about this). If you have Samba access you can simply go to the HA Config UI > Server Controls > Server Management > Stop. Then using Samba find the database file (home-assistant_v2.db) and delete it. I generally then use SSH to restart HA, or you could power cycle the server, whatever you need (I’m not familiar with the procedure for a VM)
Without Samba (and in Beau’s case, no GUI) you can achieve all this using the CLI too:
ha core stop
rm home-assistant_v2.db
ha core start
HA will restart and automatically create a new database file.
Thanks for this @sparkydave . I hope this may help others.
The issue I am having is that I am locked into the ha cli – I can not run the rm binary.
I am a bit lost as to how to navigate this cli. See here what I get when I try to rm the db
If I had SSH this would be a cinch, but the error seems to have knocked it out for now
