I have set up Homeassistant via Docker on a Raspberry Pi 4.
From docker-compose.yaml```
This works :
services:
homeassistant:
container_name: homeassistant
**image: "homeassistant/home-assistant:2023.8"**
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
If I choose the latest image :
image: "homeassistant/home-assistant:latest"
Z-wave no longer works : Newer version of Z-wave JS Server is required
You need to pull the zwave-js-ui image to download it so that it you are running a version that is compatible with Home Assistant, e.g. docker compose pull and then docker compose up -d. Be sure to read the breaking change release notes whenever you upgrade HA.
