Hi all!
I just found out I can integrate my Roborock into Home Assistant. I’m using the Xiaomi Home iOS app (which is necessary to integrate the device into HA, before I used the Roborock app). Integrating the device by providing the credentials (and checking the box “using the cloud for finding subdevices”) to the Xiaomi Miio integration works properly, I was able to control it (only tested a few basics). I saw one device with 16 entities (sensors and so on).
After that I wanted to integrate the device with its IP and the device token manually (using GitHub - PiotrMachowski/Xiaomi-cloud-tokens-extractor: This tool/script retrieves tokens for all devices connected to Xiaomi cloud and encryption keys for BLE devices., which worked very easily), but I get a lot of error messages in the logs:
2021-12-29 21:45:52 WARNING (MainThread) [homeassistant.config_entries] Config entry 'roborock.vacuum.s6' for xiaomi_miio integration not ready yet; Retrying in background
2021-12-29 21:46:17 ERROR (SyncWorker_3) [miio.miioprotocol] Got error when receiving: timed out
2021-12-29 21:46:37 ERROR (SyncWorker_1) [miio.miioprotocol] Got error when receiving: timed out
2021-12-29 21:47:07 ERROR (SyncWorker_0) [miio.miioprotocol] Got error when receiving: timed out
2021-12-29 21:47:57 ERROR (SyncWorker_2) [miio.miioprotocol] Got error when receiving: timed out
2021-12-29 21:48:17 ERROR (SyncWorker_2) [miio.miioprotocol] Got error when receiving: timed out
2021-12-29 21:49:27 ERROR (SyncWorker_5) [miio.miioprotocol] Got error when receiving: timed out
I also see the following error in the integrations page
and find neither matching services (e. g. xiaomi_miio.vacuum_remote_control_start
) nor any matching devices (in the automatic integration I found a Roborock S6
The screenshot shows that obviously the token and the IP were correct, because a roborock.vacuum.s6
was found correctly.
Does anyone know what the problem is?
My idea for the future is to remove the device from the Xiaomi cloud with Valetudo, but for the first run I want to be able to integrate it into HA properly.
