I just started having problems with the mobile_app integration. I’ve looked at the log and it doesn’t show anything at all what the problem is. No changes have been made to my config for months and now this happens. Currently running 0.109.6.
Here’s the log if, it it helps at all:
File "/usr/src/homeassistant/homeassistant/util/json.py", line 32, in load_json
return json.loads(fdesc.read()) # type: ignore
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/mobile_app/__init__.py", line 40, in async_setup
app_config = await store.async_load()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 98, in async_load
return await self._load_task
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 111, in _async_load
json_util.load_json, self.path
File "/usr/src/homeassistant/homeassistant/util/json.py", line 38, in load_json
raise HomeAssistantError(error)```
I'm pulling my hair out on this one.
