Problems with P1 and solar edge integration
Hello I am new to HA.
I having some problems with the integration for the P1 meter and Soalredge
I have tried to connect with the P! with this link: DSMR Slimme Meter - Home Assistant
I must choose for what cable I use (it is a stock USB to P1 no brand or anything on it) .
I can choose either 1 nut none of them are working?
The same with the intergration of my Solar Edge :
Solar
I have the ID and the API but it still wont work?
Thanks for the advice/help.
Greetings,
Erik.
1 problem less., The solaredge works!!
Problem solved!!
I removed the P1 cable and plugged it in Again, now it is working.
What have you done to get SolarEdge working?
At my HA it is still not working.
I just removerd the UTP cable wait for 5 minutes and plugged it in again
