I am quite new with HA therefore i hope to get some help from more experienced Colleagues
I am using Home Assistant 0.104.3 on HassOS 3.8 installed on RPi4b. I have also plugged into Rpi flashed CC2531.
From addons I have added through add-on store:
- Mosquitto broker 5.1
- zigbee2mqtt 1.9.0
After some time i was able to easily add to HA Aqara Smart LED lamp and temperature/humidity sensors. This tells me that above described setup is working.
Still i run into problems while trying to add Develco products:
- Window sensor - WISZB -120
- Smart plug - SPLZB -132
Till now i had them paired with Develco Hub (Squid Link) working with some app provided by my energy supplier.
I want to have them under HA. I have followed guidline how to pair not supported devices per zigbee2mqtt documentation (factory reset for both devices to allow pairing etc,)
Still for both of them i have received below error massage from zigbe2mqtt:
zigbee2mqtt:info 2020-01-23 17:58:51: Device â0x0015bc001e004dbdâ joined
zigbee2mqtt:info 2020-01-23 17:58:51: MQTT publish: topic âzigbee2mqtt/bridge/logâ, payload â{âtypeâ:âdevice_connectedâ,âmessageâ:{âfriendly_nameâ:â0x0015bc001e004dbdâ}}â
zigbee2mqtt:info 2020-01-23 17:58:51: Starting interview of â0x0015bc001e004dbdâ
zigbee2mqtt:info 2020-01-23 17:58:51: MQTT publish: topic âzigbee2mqtt/bridge/logâ, payload â{âtypeâ:âpairingâ,âmessageâ:âinterview_startedâ,âmetaâ:{âfriendly_nameâ:â0x0015bc001e004dbdâ}}â
zigbee2mqtt:error 2020-01-23 17:59:03: Failed to interview â0x0015bc001e004dbdâ, device has not successfully been paired
zigbee2mqtt:info 2020-01-23 17:59:03: MQTT publish: topic âzigbee2mqtt/bridge/logâ, payload â{âtypeâ:âpairingâ,âmessageâ:âinterview_failedâ,âmetaâ:{âfriendly_nameâ:â0x0015bc001e004dbdâ}}â
Have i missed some step? I would be very grateful for any hints how to get them working with HA.
