Problems with pool led
I have this pool led light:
imagen_foco_led
I bought a broadlink rm4 pro to control the light from home assistant but I could only capture the power-on command and I couldn’t get any other buttons to work.
I tried the same with the Moes smart rf-ir and I had the same result.
With this Moes device, I control the awning of my house perfectly (with Tuya integration and Scenes), but, the awning operates at 433MHz and the pool led light remote control operates at 315MHz.
I have installed a smart switch to control OFF mode (ON mode can do with the Smart IR-RF), but, the problem is that the first start of the light is very annoying (7 flashing colors changing quickly) and that is what I would like to change through the smart ir-rf , to set a fixed color.
Someone has been able to control these types of lights from Home Assistant?
Thanks.
