Problems with rfxcom
I’ve been working for a few weeks to convert my domoticz configuration to Home Asisstant. About 80 devices are already working and what is striking is that I have to write much less code than in domoticz. HASS is amazing! Now it is the turn to solve the latest problems surrounding rfxcom. At first hand, this environment seems a bit less friendly than with domoticz. There you can, for example, manually create a device and then adjust the operation by pressing your remote. This prevents many unnecessary devices and works friendly. But i am still understanding the full potential of HASS and RFXCOM, so thats why i asked for your help…
I have linked quite a few devices via RFX, but the alarm of my smoke detectors and my Byron DBY 22313 doorbell are not visible in http://xxxxx:8123/logbook when they are triggered…
Turning on the rfx debugging doesn’t help me either.
I checked the protocols I enabled in domoticz, in HASS and in the windows rfx utility of RFXCOM. I added those below.
I also see many rfx erorr messages in the log, which I will include, perhaps there is already a cause there.
logfile
2023-08-02 18:25:44.717 WARNING (MainThread) [homeassistant.helpers.entity] Entity sun.sun (<class 'homeassistant.components.sun.Sun'>) does not have a platform, this may be caused by adding it manually instead of with an EntityComponent helper, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
2023-08-02 18:25:47.858 DEBUG (SyncWorker_5) [homeassistant.components.rfxtrx] Using modes: ac,arc,byronsx,lighting4,x10,adlightwave,rubicson,homeconfort,lacrosse,undecoded
2023-08-02 18:25:47.868 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2023-08-02 18:25:48.188 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2023-08-02 18:25:48.199 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x00 0x01 0x02 0x53 0x30 0x2a 0x0a 0x07 0x02 0x01 0x02 0x00 0x05 0x4a 0x00 0x00 0x01 0x00 0x00
2023-08-02 18:25:48.199 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x00 0x03 0x53 0x00 0xaa 0x0a 0x07 0x02 0x00 0x00 0x00
2023-08-02 18:25:48.327 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x00 0x00 0x03 0x53 0x30 0xaa 0x0a 0x07 0x02 0x01 0x02 0x00 0x05 0x7c 0x00 0x00 0x01 0x00 0x00
2023-08-02 18:25:48.327 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2023-08-02 18:25:48.343 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x00 0x01 0x02 0x53 0x30 0xaa 0x0a 0x07 0x02 0x01 0x02 0x00 0x05 0x7c 0x00 0x00 0x01 0x00 0x00
2023-08-02 18:25:48.343 DEBUG (Thread-2 (_connect)) [RFXtrx] Status: Status [subtype=433.92MHz, firmware=48, output_power=0, devices=['ac', 'adlightwave', 'arc', 'byronsx', 'homeconfort', 'lacrosse', 'lighting4', 'rubicson', 'undecoded', 'x10']]
2023-08-02 18:25:48.345 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x03 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2023-08-02 18:25:48.486 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x07 0x03 0x07 0x43 0x6f 0x70 0x79 0x72 0x69 0x67 0x68 0x74 0x20 0x52 0x46 0x58 0x43 0x4f 0x4d
2023-08-02 18:25:51.558 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x00 0x3a 0x01 0x00 0xee 0x38 0x01 0x49
2023-08-02 18:25:51.701 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x01 0x3a 0x01 0x00 0xee 0x38 0x01 0x69
2023-08-02 18:25:51.829 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x02 0x3a 0x01 0x00 0xee 0x38 0x01 0x69
2023-08-02 18:25:51.959 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x03 0x3a 0x01 0x00 0xee 0x38 0x01 0x69
2023-08-02 18:25:52.391 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x05 0x03 0x0c 0x04 0x01 0xc0
2023-08-02 18:25:52.518 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0e 0x05 0x8a 0x01 0x03 0x01 0x1b 0x02 0x79
2023-08-02 18:25:52.630 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x09 0x03 0x10 0x06 0x23 0xa2 0x70 0x19 0xc8 0x40
2023-08-02 18:25:52.757 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0e 0x07 0x8a 0x01 0x03 0x01 0x1b 0x02 0x69
2023-08-02 18:25:52.881 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x09 0x03 0x10 0x08 0x23 0xa2 0x70 0x19 0xc8 0x40
2023-08-02 18:25:53.295 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d003a0100ee380149', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 4}}
2023-08-02 18:25:53.295 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d013a0100ee380169', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:25:53.295 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d023a0100ee380169', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:25:53.295 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d033a0100ee380169', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:25:53.295 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 3, 'sub_type': 12, 'type_string': 'nec', 'id_string': 'Undecoded', 'data': '05030c0401c0', 'values': {'Payload': bytearray(b'\x01\xc0')}}
2023-08-02 18:25:53.296 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 14, 'type_string': 'Alecto', 'id_string': '8a:01', 'data': '0a520e058a0103011b0279', 'values': {'Temperature': 76.9, 'Humidity': 27, 'Humidity status': 'normal', 'Humidity status numeric': 2, 'Battery numeric': 9, 'Rssi numeric': 7}}
2023-08-02 18:25:53.296 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 3, 'sub_type': 16, 'type_string': 'rubicson', 'id_string': 'Undecoded', 'data': '0903100623a27019c840', 'values': {'Payload': bytearray(b'#\xa2p\x19\xc8@')}}
2023-08-02 18:25:53.296 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 14, 'type_string': 'Alecto', 'id_string': '8a:01', 'data': '0a520e078a0103011b0269', 'values': {'Temperature': 76.9, 'Humidity': 27, 'Humidity status': 'normal', 'Humidity status numeric': 2, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:25:53.296 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 3, 'sub_type': 16, 'type_string': 'rubicson', 'id_string': 'Undecoded', 'data': '0903100823a27019c840', 'values': {'Payload': bytearray(b'#\xa2p\x19\xc8@')}}
2023-08-02 18:25:53.329 WARNING (MainThread) [homeassistant.config_entries] Config entry 'shield-slaapkamer' for androidtv_remote integration not ready yet: Couldn't connect to 192.168.20.56:6466; Retrying in background
2023-08-02 18:25:55.557 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'homeassistant.components.rfxtrx.switch.RfxtrxSwitch'>) is implicitly using device name by not setting its name. Instead, the name should be set to None, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+rfxtrx%22
2023-08-02 18:25:55.561 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'homeassistant.components.rfxtrx.switch.RfxtrxSwitch'>) is implicitly using device name by not setting its name. Instead, the name should be set to None, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+rfxtrx%22
2023-08-02 18:25:55.564 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'homeassistant.components.rfxtrx.switch.RfxtrxSwitch'>) is implicitly using device name by not setting its name. Instead, the name should be set to None, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+rfxtrx%22
2023-08-02 18:25:55.566 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'homeassistant.components.rfxtrx.switch.RfxtrxSwitch'>) is implicitly using device name by not setting its name. Instead, the name should be set to None, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+rfxtrx%22
2023-08-02 18:26:26.561 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d093a0100ee380149', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 4}}
2023-08-02 18:26:26.618 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.619 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.620 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.621 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.686 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x0a 0x3a 0x01 0x00 0xee 0x38 0x01 0x69
2023-08-02 18:26:26.687 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d0a3a0100ee380169', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:26:26.688 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.689 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.690 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.814 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x0b 0x3a 0x01 0x00 0xee 0x38 0x01 0x69
2023-08-02 18:26:26.815 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d0b3a0100ee380169', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:26:26.816 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.817 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.818 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.942 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x0c 0x3a 0x01 0x00 0xee 0x38 0x01 0x69
2023-08-02 18:26:26.944 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '3a:01', 'data': '0a520d0c3a0100ee380169', 'values': {'Temperature': 23.8, 'Humidity': 56, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:26:26.945 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:26.946 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 3a:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.389 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x05 0x03 0x0c 0x0d 0x01 0xc0
2023-08-02 18:26:27.391 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 3, 'sub_type': 12, 'type_string': 'nec', 'id_string': 'Undecoded', 'data': '05030c0d01c0', 'values': {'Payload': bytearray(b'\x01\xc0')}}
2023-08-02 18:26:27.501 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x0e 0x13 0x01 0x00 0xcd 0x42 0x01 0x69
2023-08-02 18:26:27.502 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '13:01', 'data': '0a520d0e130100cd420169', 'values': {'Temperature': 20.5, 'Humidity': 66, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:26:27.503 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.504 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.505 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.628 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x0f 0x13 0x01 0x00 0xcd 0x42 0x01 0x69
2023-08-02 18:26:27.630 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '13:01', 'data': '0a520d0f130100cd420169', 'values': {'Temperature': 20.5, 'Humidity': 66, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:26:27.631 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.632 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.756 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x10 0x13 0x01 0x00 0xcd 0x42 0x01 0x69
2023-08-02 18:26:27.758 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '13:01', 'data': '0a520d10130100cd420169', 'values': {'Temperature': 20.5, 'Humidity': 66, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 6}}
2023-08-02 18:26:27.759 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.760 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.761 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.884 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x0a 0x52 0x0d 0x11 0x13 0x01 0x00 0xcd 0x42 0x01 0x79
2023-08-02 18:26:27.885 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 82, 'sub_type': 13, 'type_string': 'Alecto WS1700', 'id_string': '13:01', 'data': '0a520d11130100cd420179', 'values': {'Temperature': 20.5, 'Humidity': 66, 'Humidity status': 'comfort', 'Humidity status numeric': 1, 'Battery numeric': 9, 'Rssi numeric': 7}}
2023-08-02 18:26:27.886 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.887 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:27.888 DEBUG (MainThread) [homeassistant.components.rfxtrx.sensor] Sensor update (Device ID: 13:01 Class: RFXtrxDevice Sub: 13)
2023-08-02 18:26:28.093 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c0401c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:28.126 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903100623a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:28.130 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903100823a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:28.132 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c0d01c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:28.169 WARNING (MainThread) [homeassistant.components.kodi.media_player] Unable to connect to Kodi via websocket
2023-08-02 18:26:28.869 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'homeassistant.components.sonos.media_player.SonosMediaPlayerEntity'>) is implicitly using device name by not setting its name. Instead, the name should be set to None, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+sonos%22
2023-08-02 18:26:29.109 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c0401c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:29.115 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'homeassistant.components.sonos.media_player.SonosMediaPlayerEntity'>) is implicitly using device name by not setting its name. Instead, the name should be set to None, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+sonos%22
2023-08-02 18:26:29.119 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903100623a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:29.138 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903100823a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:26:30.102 WARNING (MainThread) [homeassistant.components.kodi.media_player] Unable to connect to Kodi via websocket
2023-08-02 18:26:30.906 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c0d01c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:02.399 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c1601c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:02.638 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903101823a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:02.876 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903101a23a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:13.896 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c1b01c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:37.379 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c2001c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:37.635 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102223a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:37.875 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102423a27019c840, values=Payload=bytearray(b'#\xa2p\x19\xc8@')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:54.128 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102526698069c9ac, values=Payload=bytearray(b'&i\x80i\xc9\xac')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:54.285 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102626698069c9ac, values=Payload=bytearray(b'&i\x80i\xc9\xac')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:54.445 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102726698069c9ac, values=Payload=bytearray(b'&i\x80i\xc9\xac')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:54.609 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102826698069c9ac, values=Payload=bytearray(b'&i\x80i\xc9\xac')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:54.763 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102926698069c9ac, values=Payload=bytearray(b'&i\x80i\xc9\xac')>: Type is not JSON serializable: bytearray
2023-08-02 18:27:54.924 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=0903102a26698069c9ac, values=Payload=bytearray(b'&i\x80i\xc9\xac')>: Type is not JSON serializable: bytearray
2023-08-02 18:28:10.545 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=2403102bfe8000000004000000002000000001000000000800000000400000000200000000, values=Payload=bytearray(b'\xfe\x80\x00\x00\x00\x04\x00\x00\x00\x00 \x00\x00\x00\x01\x00\x00\x00\x00\x08\x00\x00\x00\x00@\x00\x00\x00\x02\x00\x00\x00\x00')>: Type is not JSON serializable: bytearray
2023-08-02 18:28:10.928 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c2c03d0, values=Payload=bytearray(b'\x03\xd0')>: Type is not JSON serializable: bytearray
2023-08-02 18:28:11.572 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=1, type_string=arc, id_string=Undecoded, data=0703012d1100098b, values=Payload=bytearray(b'\x11\x00\t\x8b')>: Type is not JSON serializable: bytearray
2023-08-02 18:28:12.384 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c3101c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:28:46.558 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=1, type_string=arc, id_string=Undecoded, data=070301361100098b, values=Payload=bytearray(b'\x11\x00\t\x8b')>: Type is not JSON serializable: bytearray
2023-08-02 18:28:47.388 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c3a01c0, values=Payload=bytearray(b'\x01\xc0')>: Type is not JSON serializable: bytearray
2023-08-02 18:29:07.552 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=16, type_string=rubicson, id_string=Undecoded, data=2403103ffe8000000004000000002000000001000000000800000000400000000200000000, values=Payload=bytearray(b'\xfe\x80\x00\x00\x00\x04\x00\x00\x00\x00 \x00\x00\x00\x01\x00\x00\x00\x00\x08\x00\x00\x00\x00@\x00\x00\x00\x02\x00\x00\x00\x00')>: Type is not JSON serializable: bytearray
2023-08-02 18:29:07.931 WARNING (Recorder) [homeassistant.components.recorder.table_managers.event_data] Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c4003d0, values=Payload=bytearray(b'\x03\xd0')>: Type is not JSON serializable: bytearraytype or paste code here
active protocols HASS/RFXCOM
active protocols domoticz
ac,arc,byronsx,lighting4,x10,adlightwave,rubicson,homeconfort,lacrosse,undecoded and aeblyss
active protocols pc rfxcom
ac,arc,byronsx,lighting4,x10,adlightwave,rubicson,homeconfort,lacrosse,undecoded and aeblyss and rsl/revolt, fine offset,viking, xt300, la crosse, mertik homeeasy and legrand
message pc/rfxcom, front doorbell
8/2/2023 05:05:47:006= 0913001603A106014240
Packet type = Lighting4
subtype = PT2262
Sequence nbr = 22
Code = 03A106 decimal:237830
S1- S24 = 0000 0011 1010 0001 0000 0110
Pulse = 322 µsec
Signal level = 4 -88dBm
ok, i’m one step further. The hundreds of error messages are gone. What was striking is that more protocols were active in the rfxtrx-e than supported in home assistant, see first message. I reset the rfxtrx-e and disabled all protocols and enabled the previously listed protocols via home assistant except undecoded. Everything still works as it was and the error messages are gone.
Other issues:
  1. Also noticed is that it seems like the configuration settings of rfx in home assistant, like - toggle auto-add and auto-add new entities and polling for updates didn’t work. I will check this again, especially now that the error messages are gone. An other aspect is that you can managed the same settings in two places, in system settings and in configuration.
  2. the alarm of my smoke sensors and my byron doorbell still not recognized, they were in domoticz
  3. how do i delete all the rfx devices that were automaticcaly added, and not used
  4. which setting do i use to stop automaticcaly add the device, the one in rfcxom configure or in system settings
Hello Peter,
Any progress on your Byron doorbell? I have the same problem. When I was using Domoticz, it was a lot easier to recieve a doorbell press. Now in HA it gives me headache. The Byron doorbell, I bought at Action long time ago, sends a different message every time the bell is pressed.
gr. Rob
Hi Rob,
yeah, it works
i bought the rfxlan adapter to put my old rfxtrx in.
Now i can monitor my rfx better!, Saw that my action byron bell got about 5 different codes.
So i added them all to Hass and made an automation that responces to all of them…
Here is my automation
alias: voordeurbel
description: ""
  - platform: state
    entity_id:
      - binary_sensor.x10_security_motion_detector_01b170_32
  - platform: state
    entity_id:
      - binary_sensor.x10_security_motion_detector_2902d0_32
  - platform: state
    entity_id:
      - binary_sensor.x10_security_06a240_32
  - platform: state
    entity_id:
      - siren.unknown_type_0x16_0x07_07_42
  - platform: state
    entity_id:
      - binary_sensor.pt2262_03a106
  - platform: state
    entity_id:
      - input_boolean.voordeurbelknop
    to: "on"
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: input_boolean.sirene_aanuit
            state: "on"
          - condition: state
            entity_id: binary_sensor.x10_security_bfd1a0_32
            state: "on"
        sequence:
          - service: switch.turn_on
            data: {}
              entity_id: switch.sirene
  - service: tts.google_translate_say
      entity_id: media_player.chromecast_huiskamer_nest
      message: De voordeurbel is ingedrukt
      cache: true
      language: nl
    enabled: true
  - service: notify.mobile_app_sm_s901b
      message: Voordeurbel
      title: Voordeurbel gaat
  - service: notify.pushover
      message: Voordeurbel is ingedrukt
      title: Voordeurbel
      target: pvkmobiel
    enabled: false
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
  - repeat:
      count: "10"
      sequence:
        - service: camera.snapshot
            filename: /config/www/tmp/imagesnap_straat.jpg
            entity_id: camera.straat
        - service: media_player.play_media
            media_content_type: image/jpeg
            media_content_id: /local/tmp/imagesnap_straat.jpg
        - delay:
            hours: 0
            minutes: 0
            seconds: 5
            milliseconds: 0
  - delay:
      hours: 0
      minutes: 1
      seconds: 0
      milliseconds: 0
  - service: media_player.turn_off
    data: {}
    enabled: true
  - service: switch.turn_off
    data: {}
  - service: input_boolean.turn_off
    data: {}
      entity_id: input_boolean.voordeurbelknop
mode: single
initial_state: true
Ok nice. Thanks for your respond.
My Byron doorbell button has two switches on the pcb. Number 1 is connected to the actual buttonswitch soldered on the pcb. For Domoticz I used switch number 2 to connect my relais to. Number 2 sends a different code every time, but number 1 doesn’t. So I soldered my relais to switch number 1, and everything is working fine now.
