Problems with Samba
Hello
Not to far into Home Assistant yet, but from what I have done so far it is really awesome!
I’m having problems installing Samba. I copied the configuration from here and changed the home assistant path, netbios name, and created a samba user but I still am not able to connect from windows. It will try to connect for a while and then I will eventually get a “Cannot connect to \HASSBIAN” message. I have tried everything I have read on here and nothing seems to be working.
Thanks for all the help in advance!
@Carter.Koopa The easiest way to get SAMBA setup with Hasbian, is to use the built-in installer script.It sets up everything for you and it works once completed. There is nothing for you to configure.
https://home-assistant.io/docs/hassbian/customization/ You may need to remove your install before running the script
Ok, I have gotten further, but it still isn’t fully working. I can see the homepi folder but not the home assistant folder.
Paste in your SMB.conf file…
