Problems with sonoff usb 3 as router and HA Yellow
I hope someone can help with this because I cant find any info anywhere.
I have the Sonoff usb 3 pro had it since before I had the yellow, when the yellow came I just switched to that and use the onboard zigbee coordinator with ZHA
I wanted to use the Sonoff as a router so followed tutorials to flash with router firmware. I followed a Mark Watt video but with the smartrf flasher I just kept getting an error something about “Unknown record type: 3”
So i went down the python route.
All seems to go fine until I try and add my newly flashed router because when ZHA says the device is ready to use its actually the existing coordinator NabuCasa Yellow EZSP not the sonoff.
If I flash the Sonoff back to coordinator it doesn’t see it when i try and add the firmware is definitely changing but as I say I cant seem to add it as a router.
I have currently only 18 devices on the zigbee network and when i try and find the sonoff I still have 18 despite it saying its ready for use but obviously that’s because its seeing yellow one.
Any help greatly appreciated as I would like to re-purpose this stick and hopefully improve the stability of my network. I currently have hue devices that drop off at random but when I’ve mentioned that in other threads many people have said theirs are fine so I was hoping by adding a few more routers I would fix this.
