rajan
(Raivo Kask)
August 13, 2022, 10:34am
1
When updating to the latest HA version (2022.8.4) I received error message:
The ‘spotify’ option near /config/configuration.yaml:1 has been removed, please remove it from your configuration
OK … I remove the 3 lines from /config/configuration.yaml
spotify:
client_id: !secret homeassistant_client_id
client_secret: !secret homeassistant_client_secret
and followed guidelines (1-9) in Spotify - Home Assistant
In Configuration section in guideline it tells me that Spotify can be auto-discovered by Home Assistant and it was in “Discovered”
Selected it resulted in error message:
INVALID_CLIENT: Invalid redirect URI
https://accounts.spotify.com/authorize?response_type=code&client_id=62dd0c221da84dd09ac0947c00813d44&redirect_uri=https://my.home-assistant.io/redirect/oauth&state=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJmbG93X2lkIjoiYWM3YjY3ZDAyZGEwNDI1Y2QxMTA4M2E2NzAxY2M0Y2IiLCJyZWRpcmVjdF91cmkiOiJodHRwczovL215LmhvbWUtYXNzaXN0YW50LmlvL3JlZGlyZWN0L29hdXRoIn0.0fY44U4FyF_XqomqEijTYO3zKoRFCxG4Eec65CXSvyc&scope=user-modify-playback-state,user-read-playback-state,user-read-private,playlist-read-private,playlist-read-collaborative,user-library-read,user-top-read,user-read-playback-position,user-read-recently-played,user-follow-read
I have Home Assistant Operating System (image) installed on Raspi.
Where have I missed?
I installed this integration and it failed with ‘Invalid redirect URI’. Anyone get this working?
