Problems with starting Appdeamon 3.x after updating to 0.86.3
I recently upgraded to 0.86.3. After the update I can not start appdeamon 3.x to run HAdashboard.
I get the following error:
Can’t create container from addon_a0d7b954_appdaemon3: 500 Server Error: Internal Server Error (“stat /var/lib/docker/overlay2/xxx-init/merged/etc/hosts: structure needs cleaning”)
(at the xxx there is a long code of numbers and letters, which I replaced for xxx)
I installed the add-on, rebooted, and reinstall, but the add-on won’t start.
Hope someone knows how to solve this!
I moved this question to the appdeamon section: https://community.home-assistant.io/t/community-hass-io-add-on-appdaemon/41261/215
