Ok, so I have tried the telegram bot and works, but there is no way to get automation codes to work with telegram bot, here is my testing automation code in automation.yaml
- alias: 'Telegram Te Dice Las Temperaturas'
platform: event
event_type: telegram_text
event_data:
text: 'temperatura salon'
- service: telegram_bot.send_message
data_template:
target: --7XXXXXXX6
message: 'Hay {{ sensor.temperatura_humedad_salon_temperatura }} ºC en el salon!'
I suspect it can be the identation, but I’m a newbie in Python and yaml and I can’t see what I’m doing wrong and why it doesn’t working. Please, help, TIA
I have done the setup in polling mode. Can it be a routers problem? I can’t do port forwarding to my raspi. I do my connection to HA throw nabucasa url. What can be wrong? Looks like my telegram bot listener service is dead. I can send any text to the channel, but my HAOS in my raspberry does not receive nothing from telegram. I don’t understand why. I have read the official documentation and done my configs exactly as the examples in doc but nothing… I can send from HAOS to telegram but telegram looks like is not connected to the chats…
Hi Yardo, did you find a solution? Who is the sender of your message that you are expecting the telegram_text event works?
I notice if I write with my personal user to the bot, the event works but if the message is sent by the same bot it doesn’t detect the telegram_text event.
