Problems with text_sensor mqtt_subscribe (pool-monitor PH tds, temp)
I’m still leraning esp home and just starting to try things.
Therefore, please bear with me if the question below is simple.
About the problem:
I have built a pool monitor to monitor PH, TDS and temp. This runs via battery and solar.
Initially I did everything via the Homeassitant Api (data exchange) now I have switched to MQTT.
Basically, the sensors work and deliver their values nicely but I have also created one in Homeassitant that tells the monitor the deep-sleep times.
The problem is that the text sensor “workmode” does not contain a value after the deepsleep or boot. But if I change this in Homeassitant while the monitor is online, the monitor gets the change and has the value until the next deepsleep or reboot.
Config from HA (configuration.yaml)
mqtt:
  select:
    command_topic: pool-monitor/workmood
    options:
      - "ota"
      - "15 min"
      - "60 min"
      - "120 min"
This is the ESP-home configuration:
esphome:
  friendly_name: pool-monitor
  on_boot:
    - priority: 601
      then:
        - output.turn_on: gpio_temp #enable temp sensor
        - output.turn_off: gpio_ph
        - output.turn_off: gpio_tds
    - priority: -300
      then:
        - script.execute: check_stuff
  on_shutdown:
    priority: 710
    then:
      - output.turn_off: gpio_temp
esp32:
  board: esp32dev
  framework:
    type: arduino
deep_sleep:
  sleep_duration: 15min
globals:
  - id: delay_int
    type: int
    restore_value: no
    initial_value: '40'
  - id: loopcount
    type: int
    restore_value: no
    initial_value: '0'
  - id: loops
    type: int
    restore_value: no
    initial_value: '0'
  - id: phflex_done
    type: int
    restore_value: no
    initial_value: '0'
  - id: tds_done
    type: int
    restore_value: no
    initial_value: '0'
logger:
#  baud_rate: 0
#  level: NONE
#api:
#  encryption:
#    key: "removed"
ota:  password: "removed"
mqtt:
  broker: !secret mqtthost
  port: 1883
  username: !secret mqttuser
  password: !secret mqttpassword
  birth_message:
  will_message:
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: LIGHT
  fast_connect: true
  manual_ip:
    static_ip: removed
    gateway: removed
    subnet: removed
    dns1: removed
  ap:
    ssid: "Pool-Monitor Fallback Hotspot"
    password: "nToC36JN3K8G"
output:
  - platform: gpio
    pin: GPIO17
  - platform: gpio
    pin: GPIO16
  - platform: gpio
    pin: GPIO18
dallas:
  - pin: GPIO5
    update_interval: never
text_sensor:
  - platform: mqtt_subscribe
    name: "current workmode"
    lambda: |-
      char str[17];
      time_t currTime = id(homeassistant_time).now().timestamp;
      strftime(str, sizeof(str), "%Y-%m-%d %H:%M", localtime(&currTime));
      return  { str };
  - platform: adc
    pin: GPIO34
    attenuation: auto
    update_interval: 15s
    accuracy_decimals: 2
    filters:
      - median:
          window_size: 10
          send_every: 4
          send_first_at: 3
      - delta: 0.1
#Convert the Voltage to a battery  level (%)
  - platform: copy
    source_id: batt_voltage
    icon: "mdi:battery"
    unit_of_measurement: '%'
    filters:
      - calibrate_linear:
          - 1.8 -> 0
          - 3.1 -> 100
      - lambda: |
          if (x < 0) return 0;
          else if (x > 100) return 100;
          else return (x);
  - platform: dallas
    address: 0x203c3ce3818e3628
    name: "Pool Temperature"
    device_class: temperature
# Raw TDS Reading
  - platform: adc
    pin: GPIO32
    name: "TDS 01 Raw"
    attenuation: 6db
    unit_of_measurement: "v"
    accuracy_decimals: 3
    internal: true
# Temperature Compensated Voltage
    name: "TDS 01 TCV"
    unit_of_measurement: 'v'
    lambda: 'return ((id(tds01_raw).state) / (1 + (0.02 * ((id(pool_temperature).state) - 25.0))));'
    internal: true
# Temperature Compensated TDS
    icon: "hass:water-opacity"
    unit_of_measurement: 'PPM'
    accuracy_decimals: 0
    lambda: return (133.42*(id(temp01_comp_v).state)*(id(temp01_comp_v).state)*(id(temp01_comp_v).state) - 255.86*(id(temp01_comp_v).state)*(id(temp01_comp_v).state) + 857.39*(id(temp01_comp_v).state))*0.5;
    on_value:
      lambda: |-
        id(tds_done)++;
  - platform: copy
    source_id: phflex
    icon: "mdi:flask"
    unit_of_measurement: 'pH'
    filters:
      - calibrate_linear:
          - 2.595 -> 4
          - 2.358 -> 6.86
      - delta: 0.1
  - platform: adc
    pin: GPIO35
    attenuation: auto
    filters:
      - median:
          window_size: 10
          send_every: 4
          send_first_at: 3
    on_value:
      lambda: |-
        id(phflex_done)++;
time:
  - platform: sntp
    timezone: Europe/Amsterdam
script:
  - id: check_stuff
    then:
      - lambda: |-
          id(loopcount) = 0;
          if(id(workmode).state.empty()) { #Workaround!!
              id(delay_int) = 900;
      - while:
          condition:
            lambda: return (strcmp("ota" , id(workmode).state.c_str() ) == 0) || (id(loops) >= id(loopcount));
          then:
          - logger.log:
              format: 'Workomde is set to: %s'
              args:
                - id(workmode).state.c_str()
          - logger.log: 'Updating Sensors'
          - lambda: |-
              id(dallashub).update();
          - lambda: |-  #reseting counters
              id(phflex_done) = 0;
              id(tds_done) = 0;
          - output.turn_on: gpio_ph #enablining the ph sensor
          - delay: 70s #sensor needs time to stabilize
          - while:
              condition:
                lambda: return (id(phflex_done) <= 3);
              then:
              - delay: 1s
              - lambda: |-
                  id(phflex).update();
          - output.turn_off: gpio_ph #disabling the ph sensor
          - output.turn_on: gpio_tds #enablining the tds sensor
          - delay: 5s #sensor needs time to stabilize
          - while:
              condition:
                lambda: return (id(tds_done) <= 2);
              then:
              - delay: 1s
              - lambda: |-
                  id(tds01_raw).update();
                  id(temp01_comp_v).update();
                  id(tds01_55g).update();
          - output.turn_off: gpio_tds #disabling the tds sensor
          - logger.log: 'Updating Sensors done'
          - lambda: |-
              id(refresher).update();
          - lambda: |-
              id(loopcount)++;
      - if:
          # 15 min
          condition:
            lambda: return  strcmp( id(workmode).state.c_str(), "15 min") == 0;
          then:
          - lambda: |
          - logger.log: 'Delay set to 15 min'
      - if:
          # 60 min
          condition:
            lambda: return  strcmp( id(workmode).state.c_str(), "60 min") == 0;
          then:
          - lambda: |
                                              id(delay_int) = 3600;
          - logger.log: 'Delay set to 60 min'
      - if:
          # 120 min
          condition:
            lambda: return  strcmp( id(workmode).state.c_str(), "120 min") == 0;
          then:
          - lambda: |
                                              id(delay_int) = 7200;
          - logger.log: 'Delay set to 120 min'
      - lambda: |
          auto now = id(homeassistant_time).now().timestamp;
          auto timefuture = now + id(delay_int);
          timefuture -= (timefuture % 60);
          ESP_LOGI("UGH", "Next target runtime: %d", timefuture);
          id(delay_int) = timefuture - now ;
      - logger.log: 'Entering sleep'
      - deep_sleep.enter:
          sleep_duration: !lambda return id(delay_int) * 1000;   #lambdas should return value as ms
captive_portal:
Log-Output after boot / wakeup:
[12:21:05][D][main:250]: Workomde is set to:
[12:21:05][D][main:253]: Updating Sensors
Logoutput when changeing the Workmode while the monitor is online:
[12:21:22][D][text_sensor:064]: 'current workmode': Sending state '15 min'
[12:21:24][D][text_sensor:064]: 'current workmode': Sending state 'ota'
[12:22:18][D][sensor:094]: 'Flex ph': Sending state 2.30028 V with 3 decimals of accuracy
[12:22:18][D][sensor:094]: 'pH Sensor': Sending state 7.55659 pH with 2 decimals of accuracy
[12:22:22][D][sensor:094]: 'Flex ph': Sending state 2.30827 V with 3 decimals of accuracy
[12:22:26][D][sensor:094]: 'Flex ph': Sending state 2.31077 V with 3 decimals of accuracy
[12:22:26][D][sensor:094]: 'pH Sensor': Sending state 7.43001 pH with 2 decimals of accuracy
[12:22:30][D][sensor:094]: 'Flex ph': Sending state 2.31876 V with 3 decimals of accuracy
[12:22:36][D][sensor:094]: 'TDS 01 Raw': Sending state 0.10700 v with 3 decimals of accuracy
[12:22:36][D][sensor:094]: 'TDS 01 TCV': Sending state 0.10581 v with 3 decimals of accuracy
[12:22:36][D][sensor:094]: 'TDS-01': Sending state 44.00683 PPM with 0 decimals of accuracy
[12:22:37][D][sensor:094]: 'TDS 01 Raw': Sending state 0.10700 v with 3 decimals of accuracy
[12:22:37][D][sensor:094]: 'TDS 01 TCV': Sending state 0.10581 v with 3 decimals of accuracy
[12:22:37][D][sensor:094]: 'TDS-01': Sending state 44.00683 PPM with 0 decimals of accuracy
[12:22:38][D][sensor:094]: 'TDS 01 Raw': Sending state 0.10700 v with 3 decimals of accuracy
[12:22:38][D][sensor:094]: 'TDS 01 TCV': Sending state 0.10581 v with 3 decimals of accuracy
[12:22:38][D][sensor:094]: 'TDS-01': Sending state 44.00683 PPM with 0 decimals of accuracy
[12:22:38][D][main:283]: Updating Sensors done
[12:22:38][D][text_sensor:064]: 'Last refresh': Sending state '2023-08-17 12:22'
[12:22:38][D][main:250]: Workomde is set to: ota
[12:22:38][D][main:253]: Updating Sensors
[12:22:39][D][dallas.sensor:143]: 'Pool Temperature': Got Temperature=25.6°C
[12:22:39][D][sensor:094]: 'Pool Temperature': Sending state 25.56250 °C with 1 decimals of accuracy
[12:23:52][D][sensor:094]: 'Flex ph': Sending state 2.33374 V with 3 decimals of accuracy
[12:23:53][D][sensor:094]: 'pH Sensor': Sending state 7.15272 pH with 2 decimals of accuracy
[12:23:56][D][sensor:094]: 'Flex ph': Sending state 2.33524 V with 3 decimals of accuracy
[12:24:01][D][sensor:094]: 'Flex ph': Sending state 2.34423 V with 3 decimals of accuracy
[12:24:01][D][sensor:094]: 'pH Sensor': Sending state 7.02614 pH with 2 decimals of accuracy
[12:24:05][D][sensor:094]: 'Flex ph': Sending state 2.34423 V with 3 decimals of accuracy
[12:24:11][D][sensor:094]: 'TDS 01 Raw': Sending state 0.10700 v with 3 decimals of accuracy
[12:24:11][D][sensor:094]: 'TDS 01 TCV': Sending state 0.10581 v with 3 decimals of accuracy
[12:24:11][D][sensor:094]: 'TDS-01': Sending state 44.00683 PPM with 0 decimals of accuracy
[12:24:12][D][sensor:094]: 'TDS 01 Raw': Sending state 0.10700 v with 3 decimals of accuracy
[12:24:12][D][sensor:094]: 'TDS 01 TCV': Sending state 0.10581 v with 3 decimals of accuracy
[12:24:12][D][sensor:094]: 'TDS-01': Sending state 44.00683 PPM with 0 decimals of accuracy
[12:24:13][D][sensor:094]: 'TDS 01 Raw': Sending state 0.10700 v with 3 decimals of accuracy
[12:24:13][D][sensor:094]: 'TDS 01 TCV': Sending state 0.10581 v with 3 decimals of accuracy
[12:24:13][D][sensor:094]: 'TDS-01': Sending state 44.00683 PPM with 0 decimals of accuracy
The projekt is still in development so some of the delay lines will be removed and also a clenup will be done.
But can anyone give me a tip on how to solve the workmode problem?
Spelling perhaps?
Thanks, but was not the problame as it si in both configs (copy/past).
But changed it.
i have solved it by using globals. details follow
As announced, here is the solution to my problem.
It still feels like a workaround but after checking all (found) sources, this seems to be the only solution.
First, there was the obvious mistake of not setting the workmode in HA to retain. By this change the monitor gets the setting even if it was offline at the point where it was changed.
mqtt:
  select:
    command_topic: pool-monitor/workmode
    retain: true
    options:
      - "ota"
      - "15 min"
      - "60 min"
      - "120 min"
Now to the bigger customization, the ESP doesn’t store the MQTT values itself, so I had to make a global in which I store the respective setting, for optimization I set it to a representative int which is handled in the on_message of the mqtt client.
By setting the global to restore_value: yes, the problem was solved.
There are also other customizations in the version (batterlevel etc.)
esphome:
  on_boot:
    - priority: 601
      then:
    - priority: -300
      then:
  on_shutdown:
    priority: 710
    then:
esp32:
  board: esp32dev
  framework:
    type: arduino
deep_sleep:
  sleep_duration: 15min #We override this on call
globals:
  - id: delay_int
    type: int
    restore_value: no
    initial_value: '40'
  - id: loopcount
    type: int
    restore_value: no
    initial_value: '0'
  - id: loops
    type: int
    restore_value: no
    initial_value: '0'
  - id: phflex_done
    type: int
    restore_value: no
    initial_value: '0'
  - id: tds_done
    type: int
    restore_value: no
    initial_value: '0'
  - id: temp_done
    type: int
    restore_value: no
    initial_value: '0'
  - id: workmode
    type: int
    restore_value: yes
    initial_value: '0'
    # 0 ==> ota
    # 1 ==> 15 min
    # 2 ==> 60 min
    # 3 ==> 120 min
  - id: tds_offset
    type: float
    restore_value: no
    initial_value: '0'
logger:
#  baud_rate: 0
#  level: NONE
# Enable Home Assistant API
#api:
#  encryption:
#    key: "removed"
ota:
  password: "removed"
mqtt:
  port: 1883
  birth_message:
  will_message:
  on_message:
    - topic: pool-monitor/workmode
      payload: 'ota'
      then:
        - logger.log: 'setting ota Mode'
        - lambda: |-
            id(workmode) = 0;
      payload: '15 min'
      then:
        - logger.log: 'setting 15 min Mode'
        - lambda: |-
            id(workmode) = 1;
      payload: '60 min'
      then:
        - logger.log: 'setting 60 min Mode'
        - lambda: |-
            id(workmode) = 2;
      payload: '120 min'
      then:
        - logger.log: 'setting 120 min Mode'
        - lambda: |-
            id(workmode) = 3;
wifi:
  fast_connect: true
  manual_ip:
    static_ip: removed
    gateway: removed
    subnet: removed
    dns1: removed
  ap:
    password: "removed"
output:
  - platform: gpio
    pin: GPIO18
  - platform: gpio
    pin: GPIO17
  - platform: gpio
    pin: GPIO19
dallas:
  - pin: GPIO5
text_sensor:
    lambda: |-
      char str[17];
      return  { str };
  - platform: adc
    pin: GPIO33
    attenuation: auto
    update_interval: 3s
    filters:
      - multiply: 2.03
      - median:
          window_size: 10
          send_every: 4
          send_first_at: 3
      - delta: 0.1 #Only send values to HA if they change
  - platform: copy
    icon: "mdi:battery"
    filters:
      lambda: |-
          float voltage = x;
          float  percentage = 2808.3808 * pow(voltage, 4) - 43560.9157 * pow(voltage, 3) + 252848.5888 * pow(voltage, 2) - 650767.4615 * voltage + 626532.5703;
          if (voltage > 4.19) {
                  percentage = 100;
                } else {
                  if (voltage <= 3.50) percentage = 0;
          return percentage;
  - platform: dallas
    filters:
      - offset: -1.4
    on_value:
      lambda: |-
        id(temp_done)++;
# Raw TDS Reading
  - platform: adc
    pin: GPIO32
    name: "TDS 01 Raw"
    #attenuation: 6db
    internal: true
    name: "TDS 01 TCV"
    lambda: |-
      return (((id(tds01_raw).state) - id(tds_offset)) / (1 + (0.02 * ((id(pool_temperature).state) - 25.0))));
    lambda: |-
      float voltage = id(temp01_comp_v).state;
      return (133.42 / voltage * voltage * voltage - 255.86 * voltage * voltage + 857.39* voltage)*0.5;
    on_value:
      lambda: |-
        id(tds_done)++;
  - platform: copy
    source_id: phflex
    icon: "mdi:flask"
    filters:
      - calibrate_linear:
          - 2.37 -> 4
          - 2.15 -> 6.86
      - delta: 0.1
  - platform: adc
    pin: GPIO35
    attenuation: auto
    filters:
      - median:
          window_size: 10
          send_every: 4
          send_first_at: 3
    on_value:
      lambda: |-
        id(phflex_done)++;
time:
  - platform: sntp
script:
  - id: check_stuff
    then:
      - while:
          condition:
            lambda: return (id(workmode) == 0) || (id(loops) >= id(loopcount));
          then:
              id(tds_done) = 0;
              id(temp_done) = 0;
          - while:
                condition:
                  lambda: return (id(temp_done) <= 1);
                then:
                - delay: 1s
                - lambda: |-
          - delay: 60s #sensor needs time to stabilize
          - while:
              condition:
              then:
              - delay: 2s
              - lambda: |-
          - delay: 3s #sensor needs time to stabilize
          - while:
              condition:
              then:
              - delay: 1s
              - lambda: |-
          - lambda: |-
          - lambda: |-
              id(loopcount)++;
          - delay: 1s #time to Update the Mqtt topics
      - if:
          # 15 min
          condition:
            lambda: return  id(workmode) == 1;
          then:
          - lambda: |
      - if:
          # 60 min
          condition:
            lambda: return  id(workmode) == 2;
          then:
          - lambda: |
      - if:
          # 120 min
          condition:
            lambda: return  id(workmode) == 3;
          then:
          - lambda: |
      - lambda: |
      - deep_sleep.enter:
captive_portal:
