Hello there =)
I am currently starting with ESPHome while following this blogpost. Everything went great until I stumbled across one issue I am currently not able to fix:
I am trying to read the input state of pins of the ESP32 and send this data to Homeassistant. This works (as described in the blogpost) for pins 12
and 13
. However I’d like to read the state of a third pin but cannot get this to work. I can’t get any other pin to read the state just like pins 12
and 13
The logical way would be to use pin 11
however esphome says this pin is used for Interrupts. I tried numerous other pins but cant find one that works. Essentially it should just recognize when the pin is connected to ground.
Looking at the documentation for the pinout I can’t figure out why other pins (like 18
/D15
) don’t work.
This is the config I use
binary_sensor:
- platform: gpio
pin:
number: 13
inverted: true
mode:
input: true
pullup: true
device_class: occupancy
- platform: gpio
pin:
number: 12
inverted: true
mode:
input: true
pullup: true
# A pin for Bedsensor right is missing
Do you have any idea? I’d be really grateful for any clues!
Cheers,
Felix
