Problems with Tibber Costum after HA Update
after installing the last HA-Core Update i have the following Error Message and Problems with using the Tibber_Costuom Tool.
Have someone any idea how i can fix the Problem?
Unable to install package matplotlib: error: subprocess-exited-with-error × python setup.py bdist_wheel did not run successfully. │ exit code: 1 ╰─> [579 lines of output] Edit mplsetup.cfg to change the build options; suppress output with --quiet. BUILDING MATPLOTLIB python: yes [3.12.1 (main, Jan 4 2024, 11:43:50) [GCC 13.2.1 20231014]] platform: yes [linux] tests: no [skipping due to configuration] macosx: no [Mac OS-X only] /usr/local/lib/python3.12/site-packages/setuptools/__init__.py:80: _DeprecatedInstaller: setuptools.installer and fetch_build_eggs are deprecated. !! ******************************************************************************** Requirements should be satisfied by a PEP 517 installer. If you are using pip, you can try `pip install --use-pep517`. ******************************************************************************** !!
