### The problem
Whenever the Z-Wave JS add-on is restarted (such as when a vers…ion update is performed) while Home Assistant is running, any value_updated triggers in automations stop working. I have to restart Home Assistant after the Z-Wave JS add-on to get the triggers to work again. In the zwave_js integration debug logs I always see the same messages whether the automation is triggered or not, and I've pasted those in the logs section. In developer tools I tried subscribing to events, and only see the event below when Home Assistant starts after the Z-Wave JS add-on.
event_type: automation_triggered
name: Start Back Yard Timer
entity_id: automation.start_back_yard_timer
source: Z-Wave value 3-38-0-targetValue updated on In-Wall 600W Dimmer
origin: LOCAL
time_fired: "2023-02-23T03:58:25.266744+00:00"
context:
parent_id: null
user_id: null
### What version of Home Assistant Core has the issue?
2023.2.5
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
zwave_js
### Link to integration documentation on our website
_No response_
### Diagnostics information
[config_entry-zwave_js-df74f956572afe21ee1a9a59e999b3ec.json.txt](https://github.com/home-assistant/core/files/10810070/config_entry-zwave_js-df74f956572afe21ee1a9a59e999b3ec.json.txt)
### Example YAML snippet
```yaml
- platform: zwave_js.value_updated
device_id: 1ad599f3cd18298ab0fc3bef72ecbae8
command_class: 38
property: targetValue
endpoint: "0"
to: "99"
condition:
- condition: or
conditions:
- condition: sun
after: sunset
- condition: sun
before: sunrise
- service: timer.start
duration: "{{ state_attr('timer.backyard','duration') }}"
entity_id: timer.backyard
mode: single
### Anything in the logs that might be useful for us?
```txt
2023-02-22 21:16:20.834 DEBUG (MainThread) [zwave_js_server] Publishing message:
{'command': 'node.set_value',
'messageId': '52ba20aa5730415b93dd501daddecb0f',
'nodeId': 3,
'options': {'transitionDuration': 'default'},
'value': 99,
'valueId': {'commandClass': 38, 'endpoint': 0, 'property': 'targetValue'}}
2023-02-22 21:16:20.872 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"statistics updated","statistics":{"messagesTX":10,"messagesRX":49,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0}}}', extra='')
2023-02-22 21:16:20.910 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"statistics updated","nodeId":3,"statistics":{"commandsTX":6,"commandsRX":4,"commandsDroppedRX":0,"commandsDroppedTX":0,"timeoutResponse":0,"rtt":47.3,"rssi":-72,"lwr":{"protocolDataRate":2,"repeaters":[],"rssi":-72,"repeaterRSSI":[]}}}}', extra='')
2023-02-22 21:16:20.916 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":3,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"property":"currentValue","endpoint":0,"newValue":99,"prevValue":99,"propertyName":"currentValue"}}}', extra='')
2023-02-22 21:16:20.916 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.in_wall_600w_dimmer_2] Value currentValue/None changed to: 99
2023-02-22 21:16:20.919 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":3,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"endpoint":0,"property":"targetValue","newValue":99,"prevValue":99,"propertyName":"targetValue"}}}', extra='')
2023-02-22 21:16:20.922 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"result","success":true,"messageId":"52ba20aa5730415b93dd501daddecb0f","result":{"success":true}}', extra='')
2023-02-22 21:16:21.006 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":3,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"property":"targetValue","endpoint":0,"newValue":99,"prevValue":99,"propertyName":"targetValue"}}}', extra='')
2023-02-22 21:16:21.011 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"value updated","nodeId":3,"args":{"commandClassName":"Multilevel Switch","commandClass":38,"property":"duration","endpoint":0,"newValue":{"value":0,"unit":"seconds"},"prevValue":{"value":0,"unit":"seconds"},"propertyName":"duration"}}}', extra='')
2023-02-22 21:16:21.014 DEBUG (MainThread) [zwave_js_server] Received message:
2023-02-22 21:16:21.015 DEBUG (MainThread) [homeassistant.components.zwave_js] [light.in_wall_600w_dimmer_2] Value currentValue/None changed to: 99
2023-02-22 21:16:21.123 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"controller","event":"statistics updated","statistics":{"messagesTX":10,"messagesRX":52,"messagesDroppedRX":0,"NAK":0,"CAN":0,"timeoutACK":0,"timeoutResponse":0,"timeoutCallback":0,"messagesDroppedTX":0}}}', extra='')
2023-02-22 21:16:21.160 DEBUG (MainThread) [zwave_js_server] Received message:
WSMessage(type=<WSMsgType.TEXT: 1>, data='{"type":"event","event":{"source":"node","event":"statistics updated","nodeId":3,"statistics":{"commandsTX":7,"commandsRX":6,"commandsDroppedRX":0,"commandsDroppedTX":0,"timeoutResponse":0,"rtt":45,"rssi":-72,"lwr":{"protocolDataRate":2,"repeaters":[],"rssi":-74,"repeaterRSSI":[]}}}}', extra='')
### Additional information
_No response_
