Home assistant or the tuya switch itself constantly tries to perform an update at certain intervals. The update always fails. The problem is that the respective tuya switch seems to be too busy by the update attempt to react to the trigger signal from the home assistant - the shutters stay up or the light stays off. How can I prevent the tuya components from constantly trying to update? Is it possible to set a parameter in the config that turns off the update?
Many thanks for the help
