I really love HA with the last updates, it is becoming user friendly. Integration in GUI are perfect, but there is a catch! Sometimes integration fails on reboots, and this is a nightmare, because you can not start HA! This is happening with WLED and ESPHOME, and this should be fixed!!! Sensor/light lose wifi or something and you can not start HA - this take long time to inspect these and you get mad.
Also NETATMO integration failes few times during the day.
Please fix that or enable safe mode for failed integration!
THANK YOU!
Failing to set up an integration rarely prevents HA from starting. The integration just gets disabled. You should open issues on github for the problems you are having instead of posting in an unrelated topic.
The integration fails and HA fail, not just integration! Have reported for ESPhome, had many sensors, but had to delete ESPhome, due to failed starts of HA. Now is same happening with WLED. Only Netatmo act like you wrote.
Best to start a new thread about this, this is discussing YAML.
