unfortunately, I am unable to integrate my Co2 (ZGm05) sensor into esp home.
esphome:
platform: ESP32
board: esp32dev
wifi:
ssid:
password:
ap:
ssid:
password:
captive_portal:
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
api:
password:
ota:
password:
- platform: zyaura
clock_pin: 26
data_pin: 27
update_interval: 30s
co2:
temperature:
humidity:
Log:
[00:06:48][V][sensor:023]: 'CO2': Received new state nan
[00:06:48][D][sensor:117]: 'CO2': Sending state nan ppm with 0 decimals of accuracy
[00:06:48][VV][api.service:105]: send_sensor_state_response: SensorStateResponse {
key: 776668964
state: nan
missing_state: NO
[00:06:48][W][zyaura:086]: Sensor reported invalid data. Is the update interval too small?
[00:06:48][V][sensor:023]: 'Temperatur': Received new state nan
[00:06:48][D][sensor:117]: 'Temperatur': Sending state nan °C with 1 decimals of accuracy
key: 1344682989
state: nan
missing_state: NO
[00:06:48][V][sensor:023]: 'Luftfeuchtigkeit': Received new state nan
[00:06:48][D][sensor:117]: 'Luftfeuchtigkeit': Sending state nan % with 1 decimals of accuracy
key: 4163663571
state: nan
missing_state: NO
[00:06:49][VV][api.service:220]: on_ping_request: PingRequest {}
If I swap the pins in the config, I only get the following message. So I no longer have access. Flashing works anyway.
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.165: [Errno 111] Connection refused). Re-Trying in 1
