After a power failure I had to use a backup to recall my latest installation. Now I´m having trouble using Zwave JS. It wont start correct. I have uninstalled the addon and integration but nothing works.
Ideas?
2022-08-28T07:37:58.415Z CNTRLR « [Node 007] parameter #3 has value: -1
2022-08-28T07:37:58.433Z CNTRLR [Node 007] Interviewing Protection…
2022-08-28T07:37:58.435Z CNTRLR » [Node 007] querying protection capabilities…
2022-08-28T07:37:58.532Z CNTRLR « [Node 008] parameter #3 has value: -1
2022-08-28T07:37:58.558Z CNTRLR [Node 008] Interviewing Protection…
2022-08-28T07:37:58.559Z CNTRLR » [Node 008] querying protection capabilities…
2022-08-28T07:37:58.624Z CNTRLR » [Node 004] querying meter value (type = Electric, scale = V)…
2022-08-28T07:37:58.738Z CNTRLR « [Node 007] received protection capabilities:
exclusive control: true
timeout: true
local protection states:
· Unprotected
· ProtectedBySequence
· NoOperationPossible
RF protection states:
· Unprotected
· NoControl
· NoResponse
2022-08-28T07:37:58.742Z CNTRLR » [Node 007] querying protection status…
2022-08-28T07:37:58.819Z CNTRLR « [Node 008] received protection capabilities:
timeout: true
· Unprotected
· Unprotected
· NoControl
· NoResponse
2022-08-28T07:37:58.822Z CNTRLR » [Node 008] querying protection status…
2022-08-28T07:37:58.903Z CNTRLR » [Node 004] querying meter value (type = Electric, scale = A)…
2022-08-28T07:37:58.977Z CNTRLR « [Node 007] received protection status:
local: Unprotected
rf Unprotected
2022-08-28T07:37:58.978Z CNTRLR » [Node 007] querying protection timeout…
2022-08-28T07:37:59.052Z CNTRLR « [Node 008] received protection status:
local: Unprotected
rf Unprotected
2022-08-28T07:37:59.054Z CNTRLR » [Node 008] querying protection timeout…
2022-08-28T07:37:59.157Z CNTRLR [Node 004] SceneActuatorConfigurationCC: setting metadata
2022-08-28T07:37:59.599Z CNTRLR [Node 004] Interviewing Configuration…
2022-08-28T07:37:59.600Z CNTRLR [Node 004] ConfigurationCC: Loading configuration parameters from device confi
g
2022-08-28T07:37:59.642Z CNTRLR » [Node 004] querying parameter #3 value…
2022-08-28T07:37:59.739Z CNTRLR « [Node 007] received timeout: [Timeout: none]
2022-08-28T07:37:59.740Z CNTRLR » [Node 007] querying exclusive control node…
2022-08-28T07:37:59.816Z CNTRLR « [Node 008] received timeout: [Timeout: none]
2022-08-28T07:37:59.817Z CNTRLR » [Node 008] querying exclusive control node…
2022-08-28T07:37:59.921Z CNTRLR « [Node 004] parameter #3 has value: 1
2022-08-28T07:37:59.922Z CNTRLR » [Node 004] querying parameter #80 value…
2022-08-28T07:38:00.012Z CNTRLR « [Node 007] no node has exclusive control
2022-08-28T07:38:00.024Z CNTRLR [Node 007] Interview stage completed: CommandClasses
2022-08-28T07:38:00.025Z CNTRLR [Node 007] Interview stage completed: OverwriteConfig
2022-08-28T07:38:00.026Z CNTRLR [Node 007] Interview completed
2022-08-28T07:38:00.029Z CNTRLR [Node 007] The node is ready to be used
2022-08-28T07:38:00.032Z CNTRLR » [Node 007] Assigning SUC return route…
2022-08-28T07:38:00.086Z CNTRLR « [Node 008] no node has exclusive control
2022-08-28T07:38:00.097Z CNTRLR [Node 008] Interview stage completed: CommandClasses
2022-08-28T07:38:00.098Z CNTRLR [Node 008] Interview stage completed: OverwriteConfig
2022-08-28T07:38:00.099Z CNTRLR [Node 008] Interview completed
2022-08-28T07:38:00.101Z CNTRLR [Node 008] The node is ready to be used
2022-08-28T07:38:00.102Z CNTRLR » [Node 008] Assigning SUC return route…
2022-08-28T07:38:01.569Z CNTRLR « [Node 004] parameter #80 has value: 1
2022-08-28T07:38:01.570Z CNTRLR » [Node 004] querying parameter #90 value…
2022-08-28T07:38:01.660Z CNTRLR « [Node 004] parameter #90 has value: 1
2022-08-28T07:38:01.661Z CNTRLR » [Node 004] querying parameter #91 value…
2022-08-28T07:38:01.752Z CNTRLR « [Node 004] parameter #91 has value: 25
2022-08-28T07:38:01.754Z CNTRLR » [Node 004] querying parameter #92 value…
2022-08-28T07:38:01.855Z CNTRLR « [Node 004] parameter #92 has value: 5
2022-08-28T07:38:01.856Z CNTRLR » [Node 004] querying parameter #101 value…
2022-08-28T07:38:01.949Z CNTRLR « [Node 004] parameter #101 has value: 4
2022-08-28T07:38:01.950Z CNTRLR » [Node 004] querying parameter #102 value…
2022-08-28T07:38:02.053Z CNTRLR « [Node 004] parameter #102 has value: 8
2022-08-28T07:38:02.055Z CNTRLR » [Node 004] querying parameter #103 value…
2022-08-28T07:38:02.150Z CNTRLR « [Node 004] parameter #103 has value: 0
2022-08-28T07:38:02.152Z CNTRLR » [Node 004] querying parameter #111 value…
2022-08-28T07:38:02.245Z CNTRLR « [Node 004] parameter #111 has value: 3
2022-08-28T07:38:02.246Z CNTRLR » [Node 004] querying parameter #112 value…
2022-08-28T07:38:02.340Z CNTRLR « [Node 004] parameter #112 has value: 10
2022-08-28T07:38:02.341Z CNTRLR » [Node 004] querying parameter #113 value…
2022-08-28T07:38:02.429Z CNTRLR « [Node 004] parameter #113 has value: 10
2022-08-28T07:38:02.430Z CNTRLR » [Node 004] querying parameter #200 value…
2022-08-28T07:38:02.521Z CNTRLR « [Node 004] parameter #200 has value: 0
2022-08-28T07:38:02.521Z CNTRLR » [Node 004] querying parameter #252 value…
2022-08-28T07:38:02.616Z CNTRLR « [Node 004] parameter #252 has value: 0
2022-08-28T07:38:02.618Z CNTRLR » [Node 004] querying parameter #254 value…
2022-08-28T07:38:02.739Z CNTRLR « [Node 004] parameter #254 has value: 0
2022-08-28T07:38:02.741Z CNTRLR [Node 004] Interview stage completed: CommandClasses
2022-08-28T07:38:02.742Z CNTRLR [Node 004] Interview stage completed: OverwriteConfig
2022-08-28T07:38:02.743Z CNTRLR [Node 004] Interview completed
2022-08-28T07:38:02.745Z CNTRLR [Node 004] The node is ready to be used
2022-08-28T07:38:02.746Z CNTRLR All nodes are ready to be used
2022-08-28T07:38:02.749Z CNTRLR » [Node 004] Assigning SUC return route…
New client
Client disconnected
Code 1000:
New client
Client disconnected
Code 1000:
