A lighting profile blueprint that keeps selected lights matched to the active Time-based or State-based profile while the lights are on.
Features
Time-based profiles
- Create as many profiles as needed and activate them by specific time, sunrise/sunset, input_datetime, or Schedule.
- Custom profiles can be limited to selected days of the week and define brightness and color.
- Schedule profiles can use Additional data for brightness, color, effects, native light profiles, and other supported light settings.
- Profiles automatically change at the next configured time while the lights remain on.
State-based profiles
- Override the active Time-based profile when configured entity states match.
- Profiles are evaluated in order, with the first matching profile taking priority.
- Each profile can define its own brightness and color.
- Brightness and Color can both be disabled to use a State-based profile as a temporary hold or pause, keeping the current lighting unchanged while the profile is active.
Transitions
- Use a separate transition when the lights are first turned on.
- Time-based and State-based profile changes can use separate transitions.
This started as a way to bring several lighting automations together into one flexible setup. I wanted a dynamic blueprint where profiles can be added and combined as needed, covering brightness, color, schedules, and different situations without creating a separate automation for every new lighting rule.
Another blueprint: Activity-based lighting + profiles
