denisj
(Denis Joshua)
April 18, 2019, 10:58am
1
Hi there all,
I just want to ask an information.
I’ll go in hollyday and because my router sometime it’s blocked,
I want to know if I can set some switch in Home Assistant
with a command that shutdown the power of my router using sonoff
and after about 10 secs will turn back on in order to powen on my router.
This because if I shut down my router I have no more internet in order to power on back again.
It is possible to make a switch with a command like this please ?
Thanks all
Denis
tom_l
April 18, 2019, 11:01am
2
Yes you can using the tasmota backlog command:
Alternative firmware for ESP8266 with easy configuration using webUI, OTA updates, automation using timers or rules, expandability and entirely local control over MQTT, HTTP, Serial or KNX. Full do...
denisj
(Denis Joshua)
April 18, 2019, 11:02am
3
Ok great
thanks a lot
I’m newbe… but I have all day to try to make run
Thanks again
Denis
tom_l
April 18, 2019, 11:07am
4
This exact same question was asked a few months ago but I’m having trouble finding the topic.
I found one similar that has an example of how to publish the backlog command from HA:
I’m using Home Assistant to control the heating in our house. The computer running HA has crashed a couple of times, resulting in an awkward morning because the inside temperature is around 16°C instead of the regular 21°C. To prevent this, I have wanted for some time to create a watchdog device for my HA computer, automatically flicking the power switch if HA becomes unresponsive.
Getting inspiration from this posting , I created my watchdog device using an inexpensive Sonoff S20 smart plug fla…
EDIT: Found it (it was more than a few months ago!):
I have a remote rental property where I have a Zoom router and a Wink Hub that connect various things like thermostats, door locks, etc… which will sometimes go offline and require a reboot.
I have solved the Wink thing with a tuya switched outlet that I can manually toggle remotely to turn off/on to take care of that issue (which is very rare)
Now on the router… I would like to do the same but… turning off the router is no big deal if the tuya outlet is connected to my wan but I cannot turn i…
denisj
(Denis Joshua)
April 18, 2019, 11:12am
5
IT’S WORK !!!
Whoaw… just in couple of minutes I make it’s work with your help.
Great comunity !!!
Thanks a lot again
Denis
