Programm Sonoff to reset my rouer
Hi there all,
I just want to ask an information.
I’ll go in hollyday and because my router sometime it’s blocked,
I want to know if I can set some switch in Home Assistant
with a command that shutdown the power of my router using sonoff
and after about 10 secs will turn back on in order to powen on my router.
This because if I shut down my router I have no more internet in order to power on back again.
It is possible to make a switch with a command like this please ?
Thanks all
Denis
Yes you can using the tasmota backlog command:
Ok great :slight_smile:
thanks a lot
I’m newbe… but I have all day to try to make run :slight_smile:
Thanks again
Denis
This exact same question was asked a few months ago but I’m having trouble finding the topic.
I found one similar that has an example of how to publish the backlog command from HA:
EDIT: Found it (it was more than a few months ago!):
IT’S WORK !!!
Whoaw… just in couple of minutes I make it’s work with your help.
Great comunity !!!
Thanks a lot again
Denis
