Hey there,
I guess this has been asked a bazillion times already and I found similar topics, but not 100% what I was looking for.
So I’m looking into programmatically create a switch entity per room my vacuum knows. I achieved that easily with a python script, no problem:
vacuumEntity = data.get("vacuum")
if vacuumEntity is None:
logger.error("No vacuum entity given. Exiting...")
else:
logger.info("vacuumEntity: {:s}".format(vacuumEntity))
if hass.states.get(vacuumEntity) is None:
logger.error("Given vacuum entity '{:s}' doesn't exist. Exiting...".format(vacuumEntity))
else:
vacuumEntityNoDomain = vacuumEntity.lstrip('vacuum.')
for roomNumber in range(0, 255):
hass.states.remove("switch.{:s}_room_{:d}_selected".format(vacuumEntityNoDomain, roomNumber))
roomIds = []
if "rooms" in hass.states.get(vacuumEntity).attributes:
for map, rooms in hass.states.get(vacuumEntity).attributes["rooms"].items():
for room in rooms:
if room["id"] not in roomIds:
roomIds.append(room["id"])
logger.info(roomIds)
if len(roomIds) > 0:
for roomId in roomIds:
hass.states.set(entity_id="switch.{:s}_room_{:d}_selected".format(vacuumEntityNoDomain, roomId), new_state="off", attributes={"room_id": roomId})
BUT: The issue is I cannot use the switch.toggle
, switch.turn_on
, switch.turn_off
actions, because (I guess) they are not really knows to HA; I just created a state in the state machine.
How can I achieve to have “valid” entities created that HA knows? I would love to dynamically re-create these room entities, similar to what you can achieve with group.set
, where you can create group entities at runtime.
Sure, my rooms barely change in my house, sure I can hardcode them. It’s more a learning thing and checking if this is possible at all
Thanks and greetings,
Andy!
