The approach I’ve taken writing ESPHome config is to use a devicename
variable, to then append/prepend to sensor IDs and such.
I’ve now got multiple devices that will use the same config, but for variation on the device name (using name_add_mac_suffix: true
). This is all find & good, but for the different contexts where I then want to use devicename
: some require an underscore (_
) for word separation, and others give warning or refuse to use an underscore.
Is there a way to programmatically replace underscore for dash in a variable name to generate separate variable names that then can be used for either esphome.name
or wifi.use_address
(for example).
For example, if this were bash, I might set devicename
to hvac_ir_remote
, then where underscores aren’t allowed, I would set an entity id to: ${devicename/_/-}
, resulting in that id being set to hvac-ir-remote
