I have installed your fork but is the same. No data “PV_in_wats”:
Fri Jul 8 13:30:02 2022 INVERTER: Debug set
Fri Jul 8 13:30:02 2022 DEBUG: Current CRC: 49 C1
Fri Jul 8 13:30:02 2022 DEBUG: Send buffer hex bytes: ( 51 4d 4f 44 49 c1 0d )
Fri Jul 8 13:30:02 2022 DEBUG: 7 bytes written, 7 bytes sent, 0 bytes remaining
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 8 total bytes: 28 4c 06 07 0d 00 00 00
Fri Jul 8 13:30:03 2022 DEBUG: Found reply at byte: 5
Fri Jul 8 13:30:03 2022 DEBUG: QMOD: 8 bytes read: (L
Fri Jul 8 13:30:03 2022 DEBUG: QMOD query finished
Fri Jul 8 13:30:03 2022 DEBUG: Current CRC: B7 A9
Fri Jul 8 13:30:03 2022 DEBUG: Send buffer hex bytes: ( 51 50 49 47 53 b7 a9 0d )
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes written, 8 bytes sent, 0 bytes remaining
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 8 total bytes: 28 32 32 35 2e 34 20 34
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 16 total bytes: 39 2e 39 20 32 32 35 2e
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 24 total bytes: 34 20 34 39 2e 39 20 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 32 total bytes: 33 38 33 20 30 32 39 39
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 40 total bytes: 20 30 30 36 20 33 36 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 48 total bytes: 20 30 32 2e 30 30 20 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 56 total bytes: 30 30 20 30 30 30 20 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 64 total bytes: 30 33 35 20 30 30 2e 36
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 72 total bytes: 20 32 32 33 2e 31 20 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 80 total bytes: 30 2e 30 30 20 30 30 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 88 total bytes: 30 30 20 30 30 30 31 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 96 total bytes: 31 31 30 20 30 30 20 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 104 total bytes: 30 20 30 30 31 33 36 20
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 112 total bytes: 30 31 30 da d2 0d 00 00
Fri Jul 8 13:30:03 2022 DEBUG: Found reply at byte: 110
Fri Jul 8 13:30:03 2022 DEBUG: QPIGS: 112 bytes read: (225.4 49.9 225.4 49.9 0383 0299 006 360 02.00 000 000 0035 00.6 223.1 00.00 00000 00010110 00 00 00136 010
Fri Jul 8 13:30:03 2022 DEBUG: QPIGS query finished
Fri Jul 8 13:30:03 2022 DEBUG: Current CRC: F8 54
Fri Jul 8 13:30:03 2022 DEBUG: Send buffer hex bytes: ( 51 50 49 52 49 f8 54 0d )
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 8 total bytes: 28 32 33 30 2e 30 20 32
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 16 total bytes: 34 2e 33 20 32 33 30 2e
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 24 total bytes: 30 20 35 30 2e 30 20 32
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 32 total bytes: 34 2e 33 20 35 36 30 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 40 total bytes: 20 35 36 30 30 20 34 38
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 48 total bytes: 2e 30 20 34 36 2e 30 20
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 56 total bytes: 34 32 2e 30 20 35 36 2e
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 64 total bytes: 34 20 35 34 2e 30 20 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 72 total bytes: 20 30 33 30 20 30 36 30
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 80 total bytes: 20 30 20 31 20 33 20 39
Fri Jul 8 13:30:03 2022 DEBUG: 8 bytes read, 88 total bytes: 20 30 30 20 30 20 30 20
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 96 total bytes: 35 34 2e 30 20 30 20 31
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 104 total bytes: 20 30 30 30 6c ce 0d 00
Fri Jul 8 13:30:04 2022 DEBUG: Found reply at byte: 103
Fri Jul 8 13:30:04 2022 DEBUG: QPIRI: 104 bytes read: (230.0 24.3 230.0 50.0 24.3 5600 5600 48.0 46.0 42.0 56.4 54.0 0 030 060 0 1 3 9 00 0 0 54.0 0 1 000
Fri Jul 8 13:30:04 2022 DEBUG: QPIRI query finished
Fri Jul 8 13:30:04 2022 DEBUG: Current CRC: B4 DA
Fri Jul 8 13:30:04 2022 DEBUG: Send buffer hex bytes: ( 51 50 49 57 53 b4 da 0d )
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes written, 8 bytes sent, 0 bytes remaining
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 8 total bytes: 28 30 30 30 30 30 30 30
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 16 total bytes: 30 30 30 30 30 30 30 30
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 24 total bytes: 30 30 30 30 30 30 30 31
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 32 total bytes: 30 30 30 30 30 30 30 30
Fri Jul 8 13:30:04 2022 DEBUG: 8 bytes read, 40 total bytes: 31 30 30 30 30 ed be 0d
Fri Jul 8 13:30:04 2022 DEBUG: Found reply at byte: 40
Fri Jul 8 13:30:04 2022 DEBUG: QPIWS: 40 bytes read: (000000000000000000000010000000010000
Fri Jul 8 13:30:04 2022 DEBUG: QPIWS query finished
Fri Jul 8 13:30:04 2022 DEBUG: Start loop
INVERTER: ampfactor from config is 1.00
INVERTER: wattfactor from config is 1.00
“Inverter_mode”:3,
“AC_grid_voltage”:225.4,
“AC_grid_frequency”:49.9,
“AC_out_voltage”:225.4,
“AC_out_frequency”:49.9,
“PV_in_voltage”:223.1,
“PV_in_current”:0.6,
“PV_in_watts”:0.0,
“SCC_voltage”:0.0000,
“Load_pct”:6,
“Load_watt”:299,
“Load_va”:383,
“Bus_voltage”:360,
“Heatsink_temperature”:35,
“Battery_capacity”:0,
“Battery_voltage”:2.00,
“Battery_charge_current”:0,
“Battery_discharge_current”:0,
“Load_status_on”:1,
“SCC_charge_on”:1,
“AC_charge_on”:0,
“Battery_voltage_offset_for_fans_on”:0,
“Eeprom_version”:0,
“PV_charging_power”:136,
“Charging_to_floating_mode”:0,
“Switch_On”:1,
“Dustproof_installed”:0,
“Battery_recharge_voltage”:46.0,
“Battery_under_voltage”:42.0,
“Battery_bulk_voltage”:56.4,
“Battery_float_voltage”:54.0,
“Max_grid_charge_current”:30,
“Max_charge_current”:60,
“Out_source_priority”:1,
“Charger_source_priority”:3,
“Battery_redischarge_voltage”:54.0,
“Warnings”:“000000000000000000000010000000010000”
Thank you!
