Was chatting with @norien about having RGB LEDs changing depending on the game currently being played through Steam (detected by the Steam component), and had the idea of implementing support for Project Aurora. Aurora allows you to use multiple brands of RGB devices (like keyboards and mice) together.
After looking into the software, it seemed this would be a trivial task as they have support for custom device scripts, so a little later support was implemented for it.
You can get the files here.
To install the script simply drop RestSharp.dll
in your Aurora install directory (should be C:\Program Files\Aurora
) and home_assistant.cs
in the Script\Devices
directory. Once you have copied those files over you can open up home_assistant.cs
and input your settings as per below.
devicename
: The name that will show up in Aurora. -
haURL
: The URL of your Home Assistant instance. e.g.http://192.168.0.4:8123
haPassword
: Password for Home Assistant (can be left empty if none). -
haLEDID
: The name of RGB LEDs to control in Home Assistant. e.g.desk_lights
The script will match the LEDs to the current colour of the escape key, so makes sure anything you do in Aurora changes the escape key colour.
