Hi everyone, I built an ESPHome HVAC zone controller for 24VAC ducted systems and wanted to share it with the community.
After finding that so much stuff out there is pretty closed source, and doesnt play very well with home assistant I wanted to make something that would. It started with wiring a dev board to a bunch of other submodules. Once that was tested and proven (its been running in the attic for over a year (these little boards are robust)
I was just looking for something to control my vents so I can use a Faikin board with my AC and ditch the Advantage Air rubbish. Glad I saw this post when I did.
HI @jcianci12 Thanks. great board and really nice build quality. If you’re able to, could you please share the YAML configuration? I accidentally overwrote it while setting it up
This looks great, what an awesome project, I would buy this in a heartbeat but the WAF is a problem, she likes the physical buttons, be awesome if a wifi enabled version of the basic 4 button polyaire zone controller existed.
I’ve stumbled upon your post while working on the same project in my home. I wish I found your PCB sooner. Currently I got an 8 channel ESP32 board with terminal connectors and I’m looking to wire it like in your first photo. What is the wiring diagram for the RJ12 connectors to the terminal connectors?
