This is a mobile air conditioner, a generic device sold in Spain by the Bauhaus stores as PROKLIMA-A018-12KR2/C.
Functions:
- Modes: Cool, Dry, Fan, Sleep
- Fan Speeds: 3
- Vertical Swing
- Temperature range: 16 to 31
DP LIST
DP | Name | Type | |
1 | Power | ||
2 | Set Temperature | ºC | |
3 | Room Temperature | ºC | |
4 | Mode | ||
5 | Fan Speed | ||
103 | Sleep | boolean | |
104 | Synchronization in | min | |
105 | Out of time | min | |
11 | Purify | boolean | |
107 | Set Temperature | ||
108 | Room Temperature | ||
109 | Indicador de función | ||
110 | Horizontal Oscillation | boolean | |
15 | Vertical Oscillation | ||
20 | Fault |
It is necessary to modify climate.py, because actually localtuya doesn’t support air conditioning.
And for the min and max temperature it is necessary to modify also const.py and en.json. this is not really necessary, only in case you want it more polished.
I used as reference:
climate.py MODIFICATIONS
About line 13:
from homeassistant.components.climate.const import (
CURRENT_HVAC_HEAT,
CURRENT_HVAC_IDLE,
CURRENT_HVAC_COOL,
HVAC_MODE_COOL,
HVAC_MODE_DRY,
HVAC_MODE_FAN_ONLY,
HVAC_MODE_AUTO,
HVAC_MODE_HEAT,
HVAC_MODE_OFF,
PRESET_AWAY,
PRESET_ECO,
PRESET_HOME,
PRESET_NONE,
SUPPORT_PRESET_MODE,
SUPPORT_TARGET_TEMPERATURE,
SUPPORT_TARGET_TEMPERATURE_RANGE,
I added the following :
CURRENT_HVAC_COOL,
HVAC_MODE_COOL,
HVAC_MODE_DRY,
HVAC_MODE_FAN_ONLY,
About line 59:
HVAC_MODE_SETS = {
"manual/auto": {
HVAC_MODE_HEAT: "manual",
HVAC_MODE_AUTO: "auto",
"Manual/Auto": {
HVAC_MODE_HEAT: "Manual",
HVAC_MODE_AUTO: "Auto",
"Manual/Program": {
HVAC_MODE_AUTO: "Program",
"m/p": {
HVAC_MODE_HEAT: "m",
HVAC_MODE_AUTO: "p",
"True/False": {
HVAC_MODE_HEAT: True,
"1/0": {
HVAC_MODE_HEAT: "1",
HVAC_MODE_AUTO: "0",
"True/False (Cool)": {
"auto/cold/wet/fan": {
HVAC_MODE_COOL: "cold",
HVAC_MODE_DRY: "wet",
HVAC_MODE_FAN_ONLY: "wind",
I added the following mode_set:
“auto/cold/wet/fan”: {
HVAC_MODE_COOL: “cold”,
HVAC_MODE_DRY: “wet”,
HVAC_MODE_FAN_ONLY: “wind”,
Cold, wet and wind are specific for this device, in some other model maybe you must put fan instead of wind (check the DPS for this)
About line 59:
HVAC_ACTION_SETS = {
"True/False": {
CURRENT_HVAC_HEAT: True,
CURRENT_HVAC_COOL: True,
CURRENT_HVAC_IDLE: False,
"open/close": {
CURRENT_HVAC_HEAT: "open",
CURRENT_HVAC_COOL: "open",
CURRENT_HVAC_IDLE: "close",
"heating/no_heating": {
CURRENT_HVAC_HEAT: "heating",
CURRENT_HVAC_IDLE: "no_heating",
"Heat/Warming": {
CURRENT_HVAC_HEAT: "Heat",
CURRENT_HVAC_IDLE: "Warming",
"cooling/no_cooling": {
CURRENT_HVAC_COOL: "cooling",
CURRENT_HVAC_IDLE: "no_cooling",
About line 238:
@property
def hvac_action(self):
"""Return the current running hvac operation if supported.
Need to be one of CURRENT_HVAC_*.
if self._config.get(CONF_HEURISTIC_ACTION, False):
if self._hvac_mode == HVAC_MODE_HEAT:
if self._current_temperature < (
self._target_temperature - self._precision
self._hvac_action = CURRENT_HVAC_HEAT
if self._current_temperature == (
if self._hvac_action == CURRENT_HVAC_HEAT:
if self._hvac_action == CURRENT_HVAC_IDLE:
self._hvac_action = CURRENT_HVAC_IDLE
if (
self._current_temperature + self._precision
) > self._target_temperature:
return self._hvac_action
if self._hvac_mode == HVAC_MODE_COOL:
self._hvac_action = CURRENT_HVAC_COOL
if self._hvac_action == CURRENT_HVAC_COOL:
if (
@property
MODIFICATIONS TO SET MIN AND MAX TEMPERATURE:
In climate.py
from .common import LocalTuyaEntity, async_setup_entry
from .const import (
CONF_CURRENT_TEMPERATURE_DP,
CONF_ECO_DP,
CONF_ECO_VALUE,
CONF_HVAC_ACTION_DP,
CONF_HVAC_ACTION_SET,
CONF_HVAC_MODE_DP,
CONF_HVAC_MODE_SET,
CONF_TEMP_MAX,
CONF_TEMP_MIN,
CONF_MAX_TEMP_DP,
CONF_MIN_TEMP_DP,
CONF_PRECISION,
CONF_PRESET_DP,
CONF_PRESET_SET,
CONF_TARGET_PRECISION,
CONF_TARGET_TEMPERATURE_DP,
CONF_TEMPERATURE_STEP,
And also:
def flow_schema(dps):
"""Return schema used in config flow."""
return {
vol.Optional(CONF_TARGET_TEMPERATURE_DP): vol.In(dps),
vol.Optional(CONF_CURRENT_TEMPERATURE_DP): vol.In(dps),
vol.Optional(CONF_TEMPERATURE_STEP): vol.In(
[PRECISION_WHOLE, PRECISION_HALVES, PRECISION_TENTHS]
vol.Optional(CONF_TEMP_MIN, default=DEFAULT_MIN_TEMP): vol.Coerce(float),
vol.Optional(CONF_TEMP_MAX, default=DEFAULT_MAX_TEMP): vol.Coerce(float),
vol.Optional(CONF_MAX_TEMP_DP): vol.In(dps),
vol.Optional(CONF_MIN_TEMP_DP): vol.In(dps),
vol.Optional(CONF_PRECISION): vol.In(
vol.Optional(CONF_HVAC_MODE_DP): vol.In(dps),
vol.Optional(CONF_HVAC_MODE_SET): vol.In(list(HVAC_MODE_SETS.keys())),
vol.Optional(CONF_HVAC_ACTION_DP): vol.In(dps),
vol.Optional(CONF_HVAC_ACTION_SET): vol.In(list(HVAC_ACTION_SETS.keys())),
vol.Optional(CONF_ECO_DP): vol.In(dps),
vol.Optional(CONF_ECO_VALUE): str,
vol.Optional(CONF_PRESET_DP): vol.In(dps),
vol.Optional(CONF_PRESET_SET): vol.In(list(PRESET_SETS.keys())),
vol.Optional(CONF_TEMPERATURE_UNIT): vol.In(
[TEMPERATURE_CELSIUS, TEMPERATURE_FAHRENHEIT]
vol.Optional(CONF_TARGET_PRECISION): vol.In(
vol.Optional(CONF_HEURISTIC_ACTION): bool,
And also:
@property
def min_temp(self):
"""Return the minimum temperature."""
if self.has_config(CONF_MIN_TEMP_DP):
return self.dps_conf(CONF_MIN_TEMP_DP)
if self.has_config(CONF_TEMP_MIN):
return self._config[CONF_TEMP_MIN]
return DEFAULT_MIN_TEMP
@property
def max_temp(self):
"""Return the maximum temperature."""
if self.has_config(CONF_MAX_TEMP_DP):
return self.dps_conf(CONF_MAX_TEMP_DP)
if self.has_config(CONF_TEMP_MAX):
return self._config[CONF_TEMP_MAX]
return DEFAULT_MAX_TEMP
In const.py
# climate
CONF_TARGET_TEMPERATURE_DP = "target_temperature_dp"
CONF_CURRENT_TEMPERATURE_DP = "current_temperature_dp"
CONF_TEMPERATURE_STEP = "temperature_step"
CONF_TEMP_MAX = "max_temp"
CONF_TEMP_MIN = "min_temp"
CONF_MAX_TEMP_DP = "max_temperature_dp"
CONF_MIN_TEMP_DP = "min_temperature_dp"
CONF_PRECISION = "precision"
CONF_TARGET_PRECISION = "target_precision"
CONF_HVAC_MODE_DP = "hvac_mode_dp"
CONF_HVAC_MODE_SET = "hvac_mode_set"
CONF_PRESET_DP = "preset_dp"
CONF_PRESET_SET = "preset_set"
CONF_HEURISTIC_ACTION = "heuristic_action"
CONF_HVAC_ACTION_DP = "hvac_action_dp"
CONF_HVAC_ACTION_SET = "hvac_action_set"
CONF_ECO_DP = "eco_dp"
CONF_ECO_VALUE = "eco_value"
In \translations\en.json
About line 176:
"max_temperature_dp": "Max Temperature (optional)",
"min_temperature_dp": "Min Temperature (optional)",
"max_temp": "Max Temperature Manual (optional)",
"min_temp": "Min Temperature Manual (optional)",
"precision": "Precision (optional, for DPs values)",
"target_precision": "Target Precision (optional, for DPs values)",
ADDING THE DEVICE TO LOCALTUYA INTEGRATION
Configuration → Add a new device →
Name | Cooler (or whatever) |
ID | 1 |
Target Temperature | 2 |
Current Temperature: | 17 |
Temperature Step | 1 |
(The 2 following options in case you made the modifications for the temperature set) | |
Min Temperature Manual (optional) | 16 |
Max Temperature Manual (optional) | 31 |
Precision (optional, for DPS values) | 1 |
HVAC Mode DP (optional) | 4 |
HVAC Mode Set (optional) | auto/cold/wet/fan |
HVAC Current Action Set (optional) | cooling/no_cooling |
Eco DP (optional) | 103 |
Eco value (optional) | True |
Temperature Unit | Choose one |
Target Precision | 1 |
Fill all the entries, click SEND, and VERY IMPORTANT, in the next screen UNCHECK “Do not add more entities”
Here we are going to add some missing sensor, switch and selector related to the device, for example the Mode Selector.
Choose “select” and then SEND
Select DP 4
Valid entries, separate entries by a ;: cold;wet;wind
User Friendly options: Cold;Dehumidifier;Fan (or whatever you want)
Click on SEND, uncheck again “Do not add more entities”, then add the next entity and so on.
ENTITIES TO ADD:
Use the same name as you use to name the device, in this way the name disappears from the name of the entity but not from the description of it.
You will have a selector named Mode and an entity named select.cooler_mode
DPS | Type | Value | Name | Friendly Name | |
4 | select | cold;wet;wind | Cooler Mode | Cold;Dehumidier;Fan | |
103 | switch | Cooler Sleep / ECO | |||
5 | select | low;med;high | Cooler Fan Speed | Low;Mid;High | |
110 | switch | Cooler Oscilator | |||
20 | sensor | Cooler Failures |
And that’s all.
