I had prometheus and grafana configured some 12 months ago and to pull data from Home Assistant and display it in Grafana dashboards.
I have now reconfigured this using this docker stack but the query format seems to have changed as all my Grafana dashboards are broken and incompatible.
It is the most puzzling thing:
Previously, all i had to do was enter the Home Assistant entity_id in the Grafana query text field and a graph would be produced. This is because the prometheus component would export each sensor entity id as a distinct metrics for Prometheus
For Example:
outside_temp
Now, this simplified querying syntax is gone it appears. The example expression below is now equired to achieve the same effect.
Example:
hass_sensor_unit_c{entity="sensor.outdoor_temp"}
I need to know the unit of the metric I wish to graph (“hass_sensor_unit_c”) and then need to check in the query inspector in Grafana which metrics are available for that unit.
Is there something i am missing? Is there a way to configure Prometheus to scrape data like it used to? I do not want this grouping by metric unit, instead i want seperate ones like before.
I already posted this on the Prometheus forum and they suggest it has to do with Home Assistant and how the Prometheus component formats the information.
The compoent documentation does not show any configuration options for exporting individual entities as metrics. This used to work, wondering what happened?
