Propagate/Push Google home devices to HA
Hello all,
I would like to ask whether it is possible to propagete/push google home connected devices/integrations into home assistant itself. I know that from HA to GA it works but what about the other way ?
I am not sure whether this is a problem on my end or if this is a general feature.
My problem is that I have a broadlink rm4 mini universal remote and this device has learned the codes to control my AC and was succesfully integrated to Google assistant. In order to use it in HA I have to let HA learn all the IR codes ? Why ? Broadlink already has a preset for my device.
Is it possible to push this learned device/integration as my AC is showing in the Google Home to home assistant ?
See " Enable Device Sync"
Misread the question. It’s not possible to inject GA devices in HA.
@koying I connected my Google home with HA via nabu casa cloud, do I still need to go through the manual configuration of enable device sync ?
No clue. I did it manually.
and after setting up device sync you are able to push Google Home’s devices to HA ?
No, you can’t sync devices in Google Home to anything else. Only Google gets that information.
Thats the info I was looking for. Thank you.
