Proper way to use hadashboard camera widgets with AppDaemon 4
I’m sorry if this is covered elsewhere, there are several threads where people ran into problems with their camera widgets after api_password was deprecated, and as best I could tell there was talk about a fix in AppDaemon 4 but I can’t tell what it is. Also, for my specific situation I’m not using actual cameras, rather I’m using a “still_image_url” to show the current album from spotify, not positive how much fixes for other camera widgets apply to me. I’ve been trying different configs for a few hours now, hopefully there’s a simple AD4 solution:
My camera configuration in home assistant:
camera:
  - platform: generic
    still_image_url: http://192.168.1.17:8123{{ states.media_player.spotify.attributes.entity_picture }}
And, my widget:
spotify_album_cover:
    widget_type: camera
    entity_picture: http://192.168.1.17:8123/api/camera_proxy/camera.spotify_album_cover?{{ states.camera.spotify_album_cover.attributes.access_token }}
    refresh: 5
I used to append &api_password={…} to that entity_picture url and it worked in earlier versions, but now that no longer works.
Should I: Switch to using an entitypicture widget? (Tried, couldn’t get it to work). Switch to using a camerastream widget (Tried briefly but assumed it wouldn’t work in my case since this isn’t a real camera)? Somehow pass a long-lived access token with the request?
I did find someone who set up a proxy webserver to add an authentication header to the request, that seems rather heavy handed, is there an AppDaemon 4 solution to this problem?
Thanks a bunch for the help!
To answer my own question…not sure what I did wrong the first time but the entitypicture widget worked great for me when I tried it again and seems to solve all my problems. As outlined here:
