Pros and Cons switching from Ubuntu virtual env to VHDX HA OS
I am currently running HA on an Ubuntu server in a virtual environment. I am hesitating to switch to a HyperV VHDX HA OS image. I have more than enough resources to allocate. What would be the pros and cons of doing it?
What I can think of:
Pros
  • Easier updates
  • Easier to install add ons through the supervisor
  • Snapshots (which is not a big difference, I had a git repo for that)
Cons
  • I am not sure if I can utilize USB redirector to pass the Zwave/Zigbee dongle to the VM
What else would you add to this list?
Thank you!
Hyperv for sure does NOT support usb passthrough
My Ubuntu server is in HyperV as well, I am using a software called USD Redirector for USB passthrough. I am just not sure how could I install/run that service on the VHDX. Must be a solution for that, I will research a bit.
