Hello everyone!
I have a “Proscenic A8” purifier. Anyone know how to set it up on Home Assistant? I searched the web but found nothing …
I only found information about Proscenic vacuum products.
Please help me!
Hi, I’ve just received my A9 Air Purifier and the best way to connect it to HA is using the TUYA integration. I am using the Smart Life appto add my devices. You can easily add the TUYA integration using HACS. Note that you will need Home Assistant Supervisor to install HACS.
I like my devices to stay local though so I pull them off of the cloud using the TUYA development API and then using TUYA Local integration via HACS. Here is a video on how to add your TUYA devices: Adding Local Tuya Devices (Dekala Arkenstone Lamp) - YouTube
Currently I can only figure out adding the device as a single entity either as a fan or a switch. Hope the above helped.
This worked for me with the Pro A9 as well. Of course, all I have is a switch for it via the Tuya Local integration. Two things to point out - in Tuya IOT the only region where your devices appear (at least in the US) is in the “Western America Data Center,” regardless of whether you put your project in the Eastern America Data Center. Second, when using the Tuya Smart Life App, it needs to find the A9 via BLE. Let it run automatically after you start pairing. If you don’t see it, then from the left panel, choose “Others”, and the choose the “Other (BLE).”
