Hope this issue is placed correctly. Have found today following protocol detail which is marked as an error and have now idea what it means… any idea?
Logger: homeassistant.helpers.event
Source: components/sensor/__init__.py:594
First occurred: 10. August 2023 um 07:58:05 (964 occurrences)
Last logged: 14:37:38
Error while dispatching event for sensor.power_import to <Job track state_changed event {'sensor.power_import', 'sensor.power_solargen', 'sensor.power_export'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=191822>: <RenderInfo Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=191822> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.power_solargen', 'sensor.power_export'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for sensor.power_import to <Job track state_changed event {'sensor.power_import', 'sensor.power_solargen', 'sensor.power_export'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=193700>: <RenderInfo Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=193700> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.power_solargen', 'sensor.power_export'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for sensor.power_import to <Job track state_changed event {'sensor.power_import', 'sensor.power_solargen', 'sensor.power_export'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=194128>: <RenderInfo Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=194128> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.power_solargen', 'sensor.power_export'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for sensor.power_import to <Job track state_changed event {'sensor.power_import', 'sensor.power_solargen', 'sensor.power_export'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=194206>: <RenderInfo Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=194206> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.power_solargen', 'sensor.power_export'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for sensor.power_import to <Job track state_changed event {'sensor.power_import', 'sensor.power_solargen', 'sensor.power_export'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=194230>: <RenderInfo Template<template=({% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %} {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %} {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }} {% else %} {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }} {% endif %}) renders=194230> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.power_solargen', 'sensor.power_export'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 590, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: ''
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 274, in _async_dispatch_entity_id_event
hass.async_run_hass_job(job, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 627, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1156, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 362, in _handle_results
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 742, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 810, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 748, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 594, in state
raise ValueError(
ValueError: Sensor sensor.power_consumption has device class 'None', state class 'None' unit 'W' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '' (<class 'str'>)
