Very new (few days) to Home Assistant from domoticz and all going well after a steep learning curve. Trying to use Prowl which I used extensivley in Domoticz. Followed intructions from Prowl - Home Assistant and added the text and api key in the config.yaml file
(obvs ignore the xxxxxx’s). After reboot the prowl integration appears in the integration page.
should there be a devices or entity appearing in the prowl integration window (sorry no second pic as this is my first post and i can only add one pic!)
If so can anyone see what i’m doing wrong?
Please don’t share pictures of text. Post the actual text formatted correctly for the forum. See: https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
No an entity is not created. A notification action should be created. Go to Developer Tools → Actions and look for the notify… action
If it has not been created look in Settings → System → Logs for related errors.
EDIT: Actually it looks like this integration does create entities:
Sorry, I do not use the integration. There are currently no known issues for this integration open: Issues · home-assistant/core · GitHub
Do you see a notification action listed for prowl in Developer Tools → Actions.
You need to search for a notify action. The way you set it up, it should show up as notify.notifier_name
I’m not an Apple user anymore, but I would assume most people just install the companion apps on their OSX and iOS devices instead of using the Prowl integration.
That works! sorry still getting my head round how this all works
Thanks for the tip!
Dude. That was what I said in the first reply.
