Proximity Automation - help wanted
I have created the following automation that works great. However I was looking for some tweaks to allow it to work for all the proximity sensors I have for all the people in my house. I am trying to avoid copying the automation 4-5 times. Bonus if I can setup the same automation for all those people for SEVERAL different proximity states (ie. 5 miles, 25 miles, 50 miles)
here is the automation:
- id: 'five_miles_away_david'
  alias: David is 5 miles away and heading home
  mode: single
  - platform: numeric_state
    entity_id: proximity.david_home
    below: 5
  condition:
  - condition: and
    conditions:
    - condition: template
      value_template: '{{ states.proximity.david_home.attributes.dir_of_travel  == "towards" }}'
  - service: script.sonos_announce
    data_template:
      message: "David is 5 miles away and heading home!"
I know I can add the other proximity sensors to the trigger, but how can I check the appropriate conditions and send an appropriate message for these other sensors? (Hope this makes sense) Thanks in advance!
- id: 'five_miles_away'
  alias: Someone is 5 miles away and heading home
  mode: single
    entity_id:
      - proximity.david_home
      - proximity.joe_home
      - proximity.jane_home
    below: 5
  condition:
  - condition: and
    conditions:
      value_template: '{{ trigger.to_state.attributes.dir_of_travel  == "towards" }}'
    data_template:
      message: "{{trigger.to_state.object_id[:-5] | capitalize}} is 5 miles away and heading home!"
Hey great! Thanks for your help! HA seemed to take that just fine, I should be able to test it out later today. Much appreciated!
BTW does the [:-5] remove the last 5 characters from the Object_ID?
Yes. I’ve made an assumption that all your proximity sensors follow the same naming format as david_home. It slices off the last 5 characters leaving behind just the person’s name. If the other proximity sensors don’t adhere to the same format, then the template for message needs modification.
Thanks again!
Just a note about a housekeeping issue. You categorized this topic as ‘Share your projects’ but it’s a better fit for Configuration > Automation.
‘Share your projects’ is typically for sharing things you’ve designed and constructed (software and/or hardware projects) that serve as an example for others to use. In this case, it’s simply a request for technical assistance (for configuring an automation).
How you configured the proximity option inside configuration.yaml to have those sensors?
You directed your question to me but you should be directing it to orphan264. I have not configured any proximity sensors; I helped to fix the automation posted by orphan264.
Ok, sorry…
This is how I configure the sensors for us. This should be compatible with the automation above:
proximity:
  richard_home:
    zone: home
    devices:
      - person.richard
    tolerance: 50
  ann_home:
    zone: home
    devices:
      - person.ann
    tolerance: 50
