I have setup Proximity Sensor
With the setting in-person set to my Phone. I have also enabled Location Services on phone and app.
It always returns
I don’t know why. There is an error in the log, but I can’t determine what it is.
Any ideas?
It always returns
Any ideas?
Zone should be defined as
zone: home
However this is the default value so you may remove it
I have had the issue with my proximity sensors reporting not set when the person is at home. I have discovered that this only happens if I am using a person as the tracked “device” if I use a device tracker then it correctly reports 0 as the distance, has anyone else seen this issue and worked around it? I have multiple trackers per person hence I would rather use person than device trackers//
