Running automation to turn on/off alarm when leaving or approaching Home Zone.
This was working fine as set alarm on leaving and turned off on arriving. But now has the home nearest error. See below.
Don’t understand as distant is numeric in my mind.
I have reset the HA OS ( restored to backup that was working) , restarted all iPhones…re-installed Companion app, made sure that Always ALLOW LOCATION, maximum accuracy…
Below is my configuration and the automation code (set up in HA UI)
Error:
"In ‘numeric_state’ condition: entity sensor.home_nearest_device state ‘XXiphone’ cannot be processed as a number.
Current system on x64 running HA OS
- Core2024.12.5
- Supervisor2024.12.0
- Operating System14.1
- Frontend20241127.8
Autiomation Code:
Preformatted text` alias: Alarm Step 1 Proximity Toggle - Leave Armed. Arrived Disarrm`
description: >-
Proximity test to see if Owners are leaving or entering the Home Zone. Sets
ALARM State to ARMED AWAY or DISARMED. Sets up next automation If triggeredwhile away alarm will sound and a notification will be sent
mode: single
triggers:
- entity_id:
- zone.home
to: “0”
trigger: state
- zone.home
- entity_id:
- sensor.home_nearest_device
above: 200
trigger: numeric_state
- entity_id:
below: 200
- entity_id:
- zone.home
above: 0
conditions:
actions:
- zone.home
- choose:
- conditions:
- condition: trigger
sequence:
- Leaving
- action: alarm_control_panel.alarm_arm_away
metadata: {}
data: {}
entity_id: alarm_control_panel.home_alarm - action: notify.mobile_app_XXiphone
message: Good Bye. Home Alarm Arm away
- conditions:
- condition: and
conditions:- condition: trigger
id:- Approaching
- condition: state
state: armed_away
sequence:
- action: alarm_control_panel.alarm_disarm
metadata: {}
code: “XXXX”
entity_id: alarm_control_panel.home_alarm - action: notify.mobile_app_ssiphone15p
message: Welcome Home. Alarm Disarmed - action: notify.XXXXX
metadata: {}
message: Twilo Test
target: 1XXXXXXXX
- condition: and
- conditions:
