I am having difficulties get the proximity working correctly following the directions
https://www.home-assistant.io/integrations/proximity/
I have set up multiple zones using a zone.yaml file. All of these zones show up in Home Assistant on it’s map.
I setup proximity sensors using a yaml file
proximity:
home:
devices:
- device_tracker.bill_pixel_gps
tolerance: 50
unit_of_measurement: mi
costco:
zone: costco
devices:
tolerance: 100
xxx_xxx:
zone: bt
devices:
tolerance: 100
yyyyy:
zone: yyyy
devices:
tolerance: 100
m_m:
zone: mm
devices:
tolerance: 100
mbems:
zone: mbems
devices:
tolerance: 100
ssss:
zone: ssssz
devices:
tolerance: 100
No errors in my logs. Some of the sensors show correctly i.e 8 mi, 2 mi, where others show as “not set mi:” When reading the directions, I am not sure if the unit_of_measurement is needed for the multiple sensors. Tried it many ways and sometimes removing the unit_of_measurement from one sensor would bring back the sensor below. Obviously I am doing something wrong, just not sure what?
What I think should happen is that each of the sensors should show how many miles the device called out is from the zone called out? So if my pixel is at home each sensor should show the distance to each zone?
