It would be really nice to be able to specify container and node names in the yaml config specifying which container/VM #'s to monitor. Use case: I run a cluster with multiple nodes and all binary sensors are prefixed with the node name (which I don’t care about). I can manually edit each one, but would be much cleaner (and survive HA re-configs) if it could be defined in the yaml.
-Josh
