Proxmox Help
So I’ve migrated my setup, I now have a debian install with proxmox on it and HomeAssistant on a VM on my NUC. If I follow the normal setup instructions and add the Linux Bridge on the network it all works absolutely perfectly…until I reboot.
If I reboot I have to use the GUI on Debian directly on the NUC to remove the bridge and then readd it because after a reboot I lose all access remotely and it all goes down
Not ideal
What could be the issue? I am a linux newb so please be gentle lol
I’d suggest following this guide
https://community.home-assistant.io/t/installing-home-assistant-os-using-proxmox-7/201835
Thanks for the reply, I was initially going to use this guide but I need proxmox on a partition and not on the whole drive so followed the guide here: Install Proxmox VE on Debian Buster - Proxmox VE
