since today my Home assistant core is not starting anymore on my Proxmox VM installed with the helper script.
I expanded the file system from 32G to 64G and updated the HA core. After restart the core is not starting anymore and i get a crash notice in the HA CLI.
“core logs” gives me a uncaught exception with KeyError “previous_unique_id”
Thank you for the reply. Unfortunally i don’t exactly know how i can get the backup out of the old VM. I never activated the SSH server and it seems like its not possible to activate SSH through the CLI. If possible to get the files from the old VM i would try to restore the backup in a new machine.
Maybe you have a Proxmox Backup from the VM (before you made your changes)?
Then you could restore the old Proxmox backup (to a new VM) and try to download the Home-Assistant backup from there.
Mounted a USB Stick to the VM to transfer the backups off the machine. Backrolling on the original VM worked but Updating the Core to the newest Version always did throw the same Errors.
Installing the backup into a new VM works like a charm.
Now i learned - Backups should go on my NAS… No (proper) backup no mercy
This helped me a lot. Thank you. However, instead of restoring a backup to a new VM, I cloned the existing one that was failing and that worked as well. I am also back up and running.
