Proxmox integration wont work for me:
configuration.yaml
proxmoxve:
- host: pve.XXXX.tk
port: 8006
verify_ssl: true
realm: pam
username: !secret proxmoxuser
password: !secret proxmoxpassword
nodes:
- node: pve
vms:
- 100
- 103
- 106
- 108
- 111
containers:
- 101
- 102
- 105
- 107
Logs:
2019-12-14 12:28:26 ERROR (MainThread) [homeassistant.setup] Error during setup of component proxmoxve
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network unreachable
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 334, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f59940522d0>: Failed to establish a new connection: [Errno 101] Network unreachable
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='pve.XXXX.tk', port=8006): Max retries exceeded with url: /api2/json/access/ticket (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f59940522d0>: Failed to establish a new connection: [Errno 101] Network unreachable'))
File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File "/usr/src/homeassistant/homeassistant/components/proxmoxve/__init__.py", line 91, in setup
proxmox_client.build_client()
File "/usr/src/homeassistant/homeassistant/components/proxmoxve/__init__.py", line 140, in build_client
verify_ssl=self._verify_ssl,
File "/usr/local/lib/python3.7/site-packages/proxmoxer/core.py", line 106, in __init__
self._backend = importlib.import_module('.backends.%s' % backend, 'proxmoxer').Backend(host, **kwargs)
File "/usr/local/lib/python3.7/site-packages/proxmoxer/backends/https.py", line 125, in __init__
self.auth = ProxmoxHTTPAuth(self.base_url, user, password, verify_ssl)
File "/usr/local/lib/python3.7/site-packages/proxmoxer/backends/https.py", line 44, in __init__
data={"username": username, "password": password}).json()["data"]
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='pve.XXXX.tk', port=8006): Max retries exceeded with url: /api2/json/access/ticket (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f59940522d0>: Failed to establish a new connection: [Errno 101] Network unreachable'))
2019-12-14 12:28:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/core.py", line 1210, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service group/set
Thank you for your help!
~Marlon
