ProxMox - Zigbee Coordinator
Hello All,
hope you can help and thanks in advance.
I have the latest installation of home assistant on and old PC as a VM Proxmox device.
I have recently bought a Sonoff Zigbee 3.0 dongle as I am adding zigbee devices at the rate of knots at the moment.
It wouldnt work or auto discover. So I have updated the fiirmware as per the adviice on the internet.
Still no joy.
I logged into the proxmox machine and looked at the USB configuration…
It looks like the sonoff zigbee coordinator has the same number as a D4Mini I use as a BLE hub,
Any solutions how I can renumber the Sonoff Dongle or the D4mini running ESPHome.
Or indeed if this is the problem.
hope I have explained enough. Thanks
Rob
Show your proxmox usb settings for the HA VM
Just passthrough the ports instead of the devices. It works much better and iam passtrough BT and Zigbee in parallel without any issue. PS: iam using and recommend zigbee2mqtt instead of ZHA. (Depending on the chipset). More stable and way better interface.
How so? I’m using devices and working fine for me but easily swapped if there is a compelling reason.
I will try this. Will I need to know which port is what number etc on this basis?
Proxmox is showing you this in the UI. But you need to Check in the guest.
@rockets
Technically no real change but some devices have multiple IDs (the sonoff stick has a second bootloader, too) so you could upgrade the stick from the guest, too because you passthrough the whole USB port Independent from the device ID attached to it.
