I’m using PrusaLink on my Prusa Mini+ printer and I was hoping that because it was running locally on my network it would be integratable (that’s not a word but feels like it should be) with HA.
I’ve seen similar previous versions running on a rest sensor, but because PrusaLink requires an API key I’m not sure how I would integrate this.
I am very much a n00b at this but willing to put in the work to get it working, any help would be appreciated though
I have it working with the Wifi beta Prusalink on my mini. The API key just needs to be passed in the headers. Rest sensor for the printer telemetry looks so:
- platform: rest
resource: http://MINI_IP_ADDRESS/api/printer
name: Prusa Mini Telemetry
method: GET
scan_interval: 3
headers:
Content-Type: application/json
X-Api-Key: !secret prusalink_api_key <-- ENTER YOUR API KEY HERE, BETTER USE SECRET FILE
value_template: "OK"
json_attributes:
- "telemetry"
- "temperature"
- "state"
Rest sensor for the job telemetry looks so:
- platform: rest
resource: http://MINI_IP_ADDRESS/api/job
name: Prusa Mini Job Status
method: GET
scan_interval: 3
headers:
value_template: "{{ value_json.state }}"
json_attributes:
- "job"
- "progress"
- "state"
Endpoints will return json values that you can process using template sensors. Example:
sensors:
prusamini_state:
friendly_name: "Prusa Mini State"
value_template: "{{ state_attr('sensor.prusa_mini_telemetry', 'state')['text'] if is_state('sensor.prusa_mini_telemetry', 'OK') else None }}"
prusamini_time_remaining:
friendly_name: "Prusa Mini Job Print Time Remaining"
value_template: "{{ state_attr('sensor.prusa_mini_job_status', 'progress')['printTimeLeft'] | timestamp_custom('%H:%M:%S', 0) if is_state('sensor.prusa_mini_job_status', 'Printing') else 0 }}"
